Quote from: ibanez4life SZSwap out the rectifier tubes for JJ GZ-34s! It did wonders for my Dual Recto! Tightness, definition, and better but in a band mix! Amazing tubes!
Eh....waste of money. If you want less sag just stick to diode rectification.
Quote from: HEAVIER THAN HELL
Alternatively, you can pay well over the odds for Mesa-branded valves that are typically Chinese-made and pop them in the amp, voila!!! (instant compromised tone)
Most larger venders can select the correct tubes using the same technique that Mesa does.
(Slagging Watford Valve for not telling the whole story then not telling the whole story yourself? The brass of some people. :roll: )
Anyway.....as for the cheap Chinese made cr@p that Heavier than Hell keeps spouting....
The Rectifier comes stock with Russian made EHX preamp tubes. They're good all around preamp tubes that are a little brighter than some and give an aggressive sound in high gain amps.
The power amp comes furnished with Russian made Sovteks. Not a bad tube, but not an excellent tube. Alot of amp companies ship using these amps because they're strong enough to survive life in a shipping container. I usually recommend people upgrade to Svetlana, SED, or JJ power tubes, depending on your taste.
I think I read somewhere that Mesa recently switched to China as their new 12AX7 supplier. It should be noted that 9th generation Chinese tubes are considered very good.
As to the thread starter......Rectifiers really don't sound good at low volumes. You don't get a real feeling for their true sound until you have them up over 10:00 (or preferable higher) on the master volume. Below that the tone will tend to be thin and buzzy.
Otherwise....that Rebel Yell pickup may not be the best choice. It has a strong bottom end and is kinda scooped.....not the best charicteristics to mix with the Recto as it usually results in an undefined "farty" sound when palm muting. I've found the Recto to work best with pickups that have alot of midrange and top end with very little bottom to them.
