Started by sambo, August 12, 2006, 11:19:28 PM
Quote from: WITH FULL DISTORTIONbash me
Quote from: samboha! well who knows, i might get rid of the neck pup and just get a tap fitted on the bridge one...you know what i figured out recently!??play something on your neck pup with the tone all the way up... then if its liek a calibrated set or something... then if you play something on the bridge pup with the tone fairly down... it sounds almost identical... so see- no need for two pups!I WIN!
Quote from: _tom_Quote from: samboha! well who knows, i might get rid of the neck pup and just get a tap fitted on the bridge one...you know what i figured out recently!??play something on your neck pup with the tone all the way up... then if its liek a calibrated set or something... then if you play something on the bridge pup with the tone fairly down... it sounds almost identical... so see- no need for two pups!I WIN!WHAT?! They dont sound similar at all.
