Quote from: WITH FULL DISTORTIONQuote from: Peter AntalWhoa!!! THAT WAS F****** BRUTAL!!! :twisted: :twisted: :twisted:
Are you sure you need new pickups? You already sound great with your setup. 8) However, I agree with HTH - if you do buy BKP's some time, you might want to get a Miracle Man set. I think you should have at least one guitar that sounds as tight as a nut. :twisted:
Thats what i WANT.
Tight bass, singing highs, crushing Mids.
Q:p
JP get a MM! Take no notice of my MM clips because I think I've had my amp set up wrong!
On each of my gain channels there are Mid Shift switches. There position down is off or flat and there up position is + or boost. I think this is how it is? On my clean channel there is a 3 position switch. In the middle is flat, down is - and up is +. The middle position flat icon is the same as the gain channels mid shift icon in it's down position. See blurry pic!
I always recorded my clips with the mid shift switches in there + position. This may be why to your ears that my EQ sounded wrong!
Sorry to Hijack your post 'Johnny Boy'!! :lol:
I think you should move to Europe or the USA and look for the band you should be in there.
What else can you do to feed yourself at the moment? To make this work JP you are going to have to live 'hand to mouth' for a while but the only way it's going to happen is for you to leave where you live now and get out there and make it happen.
Here's a line I read a while back regarding making it happen from John 5, Marilyn Masons's ex guitarist. It went something like 'Do something every day to promote yourself as a guitarist and break into the music industry. Even if it's only one phone call or one email it's more than doing nothing and waiting for it to come to you' (I'm not too sure of the exact words)
All careers and jobs are like this to more or a lesser degree JP. Believe in yourself to keep positive and focused, keep up the practise and do something every day to get your presence felt!
By the way London is mega expensive and will leave you feeling bewildered! Get some money and a gigging band before you turn up here!
