Wish I had hung on to some of my gear.....
Guitars:
1966 Fender Tele (not pre CBS unfortunately)
Swapped for a 1964 Gibson SG Standard.
Amps:
50 watt Marshall Plexi with single 8x10" (pinstripe) cabinet (have n't seen many of these since)
Found this exampleReplaced with 100 watt Marshall Plexi and two 4x12" (pinstripe) cabs.
Replaced head with Orange Matamp OR100.
Got married - wife didn't think a 100 watt stack was attractive in the Lounge so ended up with various combos which she could hide in a cupboard.
The pic (damaged by flood in garage!) shows the Matamp on top of the Marshall stack with the SG.
Still have the SG but am too embarassed to use it in public :oops: It originally looked exactly like my avatar. When I got it it had several dings but was OK. Didn't come with a case so I used to carry it around in a plastic bag :roll: . Unfortunately when I was putting it in the back of the van one day I let it drop and it succombed to the dreaded early SG neck break. As guitar luthiers in rural Devon at that time were as numerous as rocking horse s**t and we had a gig the next day I repaired it myself with the help of our singer who worked in engineering. We forced as much glue as we could in the crack and replaced the plastic cover between the neck and the pickup with a metal plate through which two small bolts passed - these went through to the back of the guitar and were fixed with a nut and washer. So it appears I have got a unique SG with a semi fixed/bolt on neck. Made my own case for it - unfortunately didn't have it in this when my 100watt Plexi fell off the top of the stack onto it - good news was it missed the neck but hit the bottom left hand side and completely broke the 4 control section away from the guitar. More glue and decided it needed a refinish to cover up the glue/crack marks - stripped what was left of the cherry finish off, took all the hardware off, masked the fretboard, hung it from the light fitting in my parent's Lounge and sprayed it with a tin of white car paint. (Eat your heart out Feline :lol: ). Mum had trouble for weeks after trying to remove what she thought was dust from the funiture. Didn't like the white finish so a few weeks later I hand painted it with a tin of Woolworths black polyurethane. To add insult to injury I later added a DiMarzio Dual Sound humbucker and a brass bridge and nut. (..Ah.. I was so young, innocent and naive then..)
Have still got the original Pat No. pickups (which I'm hoping to get Tim to rewind), bridge and nut and would like to get it restored but unfortunately I'm never going to be able to replace the 1 - 2 mm of wood shaved off it when I refinished it.
