floyd rose.. yuk
Started by Muzzzz, August 25, 2006, 02:51:56 AM
blue
i got one of those tremol-no things, and it makes changing strings SOOOO much easier!  just lock it and it's like changing on a hardtail guitar.  release it, fine tune and you're away.
n_mountain
QuoteDo it one string at a time and use a stringwinder...
Yeah, stringwinders rule !!! :twisted:
I always thought if I would get tendon problems it wouldn't be by playing but by restringing  :P  but now with my cute blue stringwinder my life is intact again ;)
(oh, you wanted us to ignore this post...) 8)  :lol:
Davey
Ohh, the Planet Wave stringwinder/cutter changed my life - Genius!!!!
Muzzzz
wow.. this thread is really popular for one i didn't actually intend to make...  :roll:
{Insert witty signature HERE}
Guitarzan
I restrung my first floyd today....
I don't see why its so hard, only took me 15 min
Hey are they saddles prearranged? becasue if they are then I messed them up
JamesHealey
2 Point Fulcrum Trem, LSR Roller Ball Nut, Schaller Locking tuners..
Who needs a floyd??
maliciousteve
only takes me about 20 minutes to change strings on a floyd. Actually takes me longer to restring my PRS due to those locking PRS tuners.
Searcher
Quote from: GuitarzanHey are they saddles prearranged? becasue if they are then I messed them up
You moved the saddles?  That's gonna effects your intonation.
lp_man
If you don't use it why don't you block it?  8)
Guitarzan
Quote from: Searcher
Basically the whole bridge of my Guitar was coated in dirt and grime. I had to take it apart to get it all clean. I had it in ablut 30 pieces at one point. I "preset" my intonation similar to another of my Guitars, and it was actually almost spot on!
But I do notice some slight height differences in the saddles, that I can feel as well as see. I was just wondering if there was an easier way to tell where they go.
Sorry for the Hijack!
Searcher
Well, height differences won't effect the intonation as much moving the saddles forwards or backwards will.
There are guides to know roughly how high each saddle should be, dependinng on the guitar's neck radius, which you can find online with a search (I don't have the figures in memory).  But the way I set them is just by what feels right, according to the action and curvature of the fretboard.
As far as intonaiton goes, get yourself a tuner and do a search on how to set that, too.  It's really not difficult.  :)
Guitarzan
As far as I know the Height on floyds is already pre-set to about 14" radius.
So I'm just concerned that there might be a certain way to have the saddles set, Because the base plate else is flat.
gingataff
Are the saddle blocks different heights? if so you need the tallest to in the middle, the shortest on the outside and the other two in between. I haven't had an OFR but on an Edge the blocks are the same height and the plate is staggered.
I see a rainbow rising
Look there on the horizon
And I'm coming home
Guitarzan
Quote from: gingataffAre the saddle blocks different heights? if so you need the tallest to in the middle, the shortest on the outside and the other two in between.
They look to be slightly different, and the plate isn't staggered. But I don't think that it is an OFR either. the allen bolts that lock the strings are very short. i.e. you have to adjust them in front of the fine tuners.
I was just wondering if there was any way to tell a difference.
