Dammit my PC packs up for 2 weeks and all the decent threads come along at once! :x
My suggestion would be to go with the little Marshall clones from
www.ampmaker.com - the components are at least as good if not better than those in the 2061x and it's a reputable British company that I'd vouch for 100%.
The HW Marshalls do have on the whole slightly better components than their PCB counterparts, which helps Marshall perpetuate the myth that handwiring things makes them sound better. I don't think they're using it as an excuse to inflate the price though - the amount of time it takes to wire an amp by hand can be quite high, and bear in mind you're paying for British labour in wiring this amp at a real wage, not a chinese sweatshop. When Marshall want to inflate the price, they just make it a limited edition or slap Hendrix's name on it like the JTM 45/100's they've released - no way in hell are those amps worth several thousand pounds.
Saying that cross talk is a problem with PCB's is a bit of a moot point to be honest, since hand wired amps made in the style of the old Marshalls tend to use much longer component leads, physically larger capacitors etc to be more authentic, which increases cross talk. I've always had far more of it with turret board circuits than when using PCB's.
Marhshall didn't suddenly turn corporate or anything after the JCM800's were made - they've always been exactly the same, ie. that they know feck all about the amps they make. Marshall only used high quality components in the late 60's because that's what was there at the time - as far as they are concerned, as long as it's the right value it'll do. Marshall shouldn't have to search far and wide for good sounding examples of their old amps, they should be able to discern for themselves what makes a great sounding amplifier. By the way, for those who say that the 1959HW sounds bright or 'ratty' sounding, that's how the original amp sounded. I know the guy who owned the amp Marshall cloned for the 1959HW, and he said they made a perfect replica of it - including it's tonal flaws.
There's nothing particuarly special about any Marshall circuit, and they would all sound good as long as good components are used. If JCM900's were made in the 1960's they would probably have sounded good because Marshall will have had decent sounding transformers and capacitors in their parts bins. Those old components weren't even supposed to be 'high quality' anyway; aside from their military spec ratings, it's just a lucky coincidence that their composition means that they sound particuarly good for guitar amps. It becomes an issue when Marshall start using different components, but don't stop to think "hang on a minute, that doesn't sound as good, let's stick with the old components".
Quote from: fps_deanThat's funny because a '68 spec and '69 spec and '70s spec are all exactly the same.
That's not
strictly true; there were plenty of transitional 12000 series amps made in 1968 with bassier values (I've actually heard that all these amps were made in 68 but cant say that for sure), and it wasn't until well into 1968 (midway I believe) that the lead circuit became standardised. In addition, 70's spec is different - for some reason Marshall decided to remove the .68uF cap on V2a, and started messing with the NFB setup and presence control.
