Buzzzing problem
Started by Miracle Man, November 02, 2006, 12:30:55 PM
Miracle Man
Ok, here's the deal.
I did some tests today with my guitar and I'm not shure the "results" are normal.
The guitar is an SG type, the amp was a '77 Marshall Super Lead (no master) through a 4x12 and I used a ProCo Rat for distortion.
Here's what I noticed:
-When I touch an electronic device that is plugged in, such as a DVD player with a metal cassing in my case, I get this anoying buzz.
-When both pickups are on, the guitar is much more quiet and it doesn't feed back even if I stand in front of the amp. But when individual pickups are selected there is this humming. Not a grounding problem because it doesn't go away even when I touch the string or the bridge.
Is this normal?
Also, can someone explain guitar grounding to me?
Cheers, Troy
Muzzzz
are the humbuckers wired to do coil splits? that can make a 'bucker hum more than usual. also, other electric stuff (computers, dvd players) make pickups buzz a lot when you're around them, i've found. it's pretty normal.
Well that's all i know on the topic...
{Insert witty signature HERE}
