Pickup Height...
Started by Canadian Steve, December 14, 2006, 10:23:57 PM
everton_fc
The whole pickup height thing for me was a bit of a learning curve. One thing I learnt this week though since installing a new set of Mules last week, is to give your guitar a good going over through the set up you play live.
At home I have a cr@p practice amp, and it was with that I was initally setting the height of the pickups. Thought I had it nailed, until I went into a rehearsal room on the weekend on my own.
I plugged into my live rig, and was surprised by how it sounded - strings choking high up the neck, muddiness etc.
So I began a slow process of lowering the pickups, half a turn at a time - playing some chords, small lead runs, then making another half turn and so on - took a little while, but the results were fantastic.
I dont really have the opportunity to play through my live rig at home due to wife/kid/neighbours. But it made so much difference to me to actually set the pickup heights using the exact set up I will play live.
Just have to say, the Mules sound great - especially the bridge pickup. So much fun to play - and playing on my own in a rehearsal room, with the amp CRANKED was so much fun, highly recommended to other guys out there who are restricted to volume levels at home.
capitaine_banane
HEllo
I have 2 BK pu: a warpig in a SG and an abraxas in a LP, both in bridge position.
I installed the abraxas yesterday, in neck position is an old pu. the pus are at the same distance from the string, but the neck one sound more louder than the BK (especially in clean).
the BK sound thin and poor at this distance with no power.
I have to set the distance of the BK about 1,5 -2 mm from the string to balance the sound.
same with my warpig.
is it a particularity of BK pu to set very close to the string?
cokecan72
with my few guitars (all single coils) i've always set the pickup height so the top of the plastic cover is about 2 - 3mm higher than the scratch plate
for me it sounds good, not too quiet but not too sensative
Canadian Steve
Quote from: capitaine_banane
I would set the bridge (with the strings at the last fret pressed) at 2mm-2.5mm and the neck (with the strings depressed at the last fret) at 3.5mm-4mm
This is how I set up my RYs, hope it helps!
BKPS: Cryogenic Apache set, Mule set, Riff Raff, Stormy Monday.
capitaine_banane
Canadian Steve
Quote from: capitaine_bananethe neck is at 10mm!
:o
Do you by any chance know how hot/the DC rating the neck p'up is?  Is the guitar plugged into a guitar amp or into a mixing desk?
capitaine_banane
plugged into a tube amp.
I will check the DC.
shaman
-is it 2 or 4 conductor??when I installed my reb yell 2 conductor, some hard to see individual wires form the shielding was touching the inner wire,resulting in a weak output-sounded like a messed up single coil instead-once we pulled the shielding much farther away it was balls to wall..man
capitaine_banane
it is the 4 conductors version.
I have the two wires soldered together (for split), the red wire and black and metal wrires soldered together to the ground.
The DC of the other pu is 8k.
Sailor Charon
Quote from: callme.nastyhere in the US we don't use the metric system very much at all. I don't get why not. Metric is obviously a much easier and overall better system. Who the hell ever thought of using feet, inches, and centimeters? i think milimeters, centimeters, and meters, are much easier to work with.
Well... I'm of the generation that learnt the metric system at school, but never used it much outside school.
In truth, metric is easier to work with for more complex maths, but in everyday situations it doesn't make a lot of difference. (For example recipes tend to be for 4... [and 8 (oz) divides by 4 more neatly and less finickly than 250 (grams)... :wink: ])
Quote from: capitaine_bananeI have the two wires soldered together (for split), the red wire and black and metal wrires soldered together to the ground.
Is the red wire soldered to the first tag on the volume pot?
Muzzzz
That's true, Sailor Charon, but 250 grams is also a 1/4 kilogram.
And I believe that the Imperial System was originally based off the king's foot...
{Insert witty signature HERE}
capitaine_banane
Quote from: Philly Q
euh yes I think so, I will check.
Anyway it is soldered to the pot connected to the tone pot
