Started by TonyGibson, February 13, 2007, 02:01:52 AM
Quote from: BLOODMOUNTAINhmmmm..... my dad said that my guitar (Razorback, in case you don't know!) could only handle up to 13s...... is this true???
Quote from: the_bleedingQuote from: BLOODMOUNTAINhmmmm..... my dad said that my guitar (Razorback, in case you don't know!) could only handle up to 13s...... is this true???if you tune it to E, and put heavier strings on, the bridge might start to lean forward, and the headstock might start to bend inwards. However if you downtune, the tension will be alot less, and you should be fine. There is also the detail with filing the nut to accept thicker strings...
Quote from: BLOODMOUNTAINsurely with a locking nut, you don't have this problem?????yeah, he must be talking cr@p. (my dad). new springs, no problem. i'll remember, when i've put the strings on, not to tune to standard. maybe C# standard sounds good :twisted: BM
Quote from: the_bleedingQuote from: BLOODMOUNTAINsurely with a locking nut, you don't have this problem?????yeah, he must be talking cr@p. (my dad). new springs, no problem. i'll remember, when i've put the strings on, not to tune to standard. maybe C# standard sounds good :twisted: BMlocking nut doesnt change the amount tension your strings exert on the headstock or the neck, it just immobilizes them so a trem doesn't put them out of tune. If anything, it will redirect the tension to pull more at the nut, encouraging warping. But in C# tuning, you should definately be fine.
Quote from: Metal-Assmoneywow. u guys all amaze me. i used to use 12-52s tuned to standard E on my flying V, but found they sound to bright. I still use 11-48s and to 48s and even tune to E. if i play a guitar with standard strings my pick attack become sloppy and un-articulate, on my solos i overbend every other note and miss half my pick strokes because the string doesnt snap back to where it should before i hit it again.
Quote from: noodleplugerineQuote from: Metal-Assmoneywow. u guys all amaze me. i used to use 12-52s tuned to standard E on my flying V, but found they sound to bright. I still use 11-48s and to 48s and even tune to E. if i play a guitar with standard strings my pick attack become sloppy and un-articulate, on my solos i overbend every other note and miss half my pick strokes because the string doesnt snap back to where it should before i hit it again.You find it amazing that we don't have superhuman strength?
