Author Topic: Gibson Flying V- Ceramic Warpig or Alnico Warpig?  (Read 7292 times)
evilfrenchy
« Reply #15 on: February 28, 2007, 04:07:02 AM »
well if it is your setup(the flying v..),i m guessing you re using an 81 in the bridge(ceramic magnets) position,and a 85 inthe neck position(alnico5magnets),they both have the same output,the only difference is their magnets,so try to swap the pickups (bridge)to hear how they sound respectively,this will give you an idea about the warpigs.then again tim has to lower the output of the ceramic warpig to make it playable(18.5k,instead of 22k),so alnico5 warpig is 22k,ceramic warpig is 18.5k,cheers.
Metal-Assmoney
« Reply #16 on: February 28, 2007, 04:20:30 AM »
actually, i hated the 81 in the bridge and i run 2 85s.
but thanx for the advice.
