Nailbomb for me?
Started by cam_rock, March 07, 2007, 10:38:16 AM
cam_rock
Hey guys,
I finally got an ENGL Screamer today, and it's GORGEOUS. Anyways, now I've got my amp, I can better assess my needs pickup-wise (the stocks on my Schecter C-1 plus are very muddy). The amp is gorgeous, but obviously being EL34 based, it's got a lot of punch in the mids and sounds quite bright, whereas the guitar itself is very bassy.
The stock bridge pickup in my Schecter is based on the SD JB. I looked on their site, and their estimated EQ is bass-5, mid-6, treble-8. This, mixed with the bright and middy ENGL, makes my tone very fizzy and harsh. However, the Schecter IS a bassy guitar so I don't want to overcompensate TOO much.
I guess I'm looking for something that you could estimate the EQ at around 7ish on the bass, 6ish on the mids, and around 5-6 on the treble... Obviously I'm not looking for an uber-bassy sound, but I feel somewhere in the middle is needed to balance out the brightness of the amp and the fizziness and treble-oriented nature of the pickup.
Here's what I'm after:
- Aggressive, hot and loud rather than really gainy and saturated.
- Open, not compressed sounding.
- Lots of low-mid. Fair amount of bass, not too much upper mids and trebs, but obviously they gotta be tight.
- Lots of clarity, no muddiness whatsoever.
I think the Nailbomb's what I'm after, but I'm not sure if it has too much mids for me? Thanks.
I'd say you're after an AV Warpig
Holy Diver is another good choice there
jimmy_fowler
Thanks for the replies guys, any one else agree?
If a comparison would help, I tried out some EMGs the other day. I liked the 81 for the way palm-mutes just jumped off the fretboard. I loved how clear and tight and focused they sounded, but I found them too compressed sounding, not wide or open enough, and far too middy. So an EMG 81 with less gain and compression, more low mids and bass, and a lot wider sounding... I guess is another way of describing what I want...
Catalyst77
I'm pretty simliar to you in that I like punchy mids and god bottom end with open sounding pickups rather than compressed/focused sounds.
I think if youve got load of gain on the amp, i'd consider getting something a little less powerful in the pick up area, maybe something from the vintage hot section.  I find (although i may be wrong) that more often than not hotter pickups will compress the sound more.
cam_rock
That's exactly what I thought... The Screamer is pretty gainy so I don't want to go overboard gain-wise... Don't know what to go for though...! Hopefully someone will be able to point me in the right direction!  :D
Oli
I just recently swapped my SD JB out for a Nailbomb, and couldn't be happier- more aggressive tone, more articulate and a much better clean... so i'd vote for the Nailbomb :)
steve
Quote from: jimmy_fowlerThanks for the replies guys, any one else agree?
For my money you just described a Miracle Man.
Catalyst77
I'd have to disagree there, I had a set of MM's and I hated them, not because they werent any good, but because they were the complete opposite of what i wanted.
They are a pretty focused type of pickup, quite compressed and  not very open sounding at all.
I guess it depends what type of music you want to play.  If you want to sound like metallica/Zakk Wylde, then go for the Miracle Mans.
I too have miracle men, I've had a total of 3 bridge versions, and I've had EMGs. I based what I said on the reference point that Jimmy gave us of what he thinks of EMGs. Given that, I think MMs will be great for him. They're a lot less compressed than EMGs, they have more bass, plenty of low mids but overall much less mids, and are bigger and more natural sounding.
Catalyst77
Each to his own I guess, otherwise we'd all be playing the same stuff with the same pickups!
cam_rock
Thanks for the replies so far guys, it's so much appreciated. It's so hard to choose without being able to try, and it's pretty hard to accurately describe the tone I want.
With the Miracle Man, how bassy is it? Because although I'd like more bass, I don't want an ostensibly bassy pickup, because my guitar itself is quite bassy. Mids and low mids are where I want the focus, but with ample bass, and less treble.
In terms of the compression and gain thing, I find it hard to discern the difference sometimes. In terms of the EMGs, I liked how tight and focused they sounded, especially when palm-muting; the way every note was defined and articulated and clear. However, what I did not like was how it sounded unbelievably gainy but very narrow. Is that compression? If so, will the Miracle Man give me the clarity and definition I want without being compressed?
Thanks again.
cam_rock
Just heard Johnny Mac's MM clip:
http://bareknucklepickups.co.uk/forum/viewtopic.php?t=1341
That is gorgeous! Is that a fair representation of the bridge position MM? Also, if Johnny is reading, what neck pickup did you use? That was amazing too. Perfect clip!
Yeah, cam, thats pretty MM.
Thats not the sound I play em with (I'll give you a clue: one of mine is 23k and double screw pole for more low end  :twisted: ) but that tone there will fall right out of it
