Author Topic: Floyd Rose Screwsgot $%&#ed Up  (Read 5226 times)
WITH FULL DISTORTION
« on: March 30, 2007, 03:17:03 AM »
Hails Guys
my charvel fusion deluxe recently got $%&#ed up on the baseplate.
i mean, that routing where the screws that holds the saddles n the baseplate, are just $%&#ed up
i Mean, they doesnīt Hold the screw there anymore
is there any other solution?
itīs a made by schaller for jackson floyd rose. i think itīs the JT-6.
any clue on what could i do to fiz that problem without spend a lot fo money on buying a new complete floyd rose?
Hails and thankīs in advance
JP
metal_god
« Reply #1 on: March 30, 2007, 07:01:47 PM »
i dont have a clue what you said hehe but if the screws are coming out then stuff about 4 matches in there with glue and your problems will be sorted
WraithChild
« Reply #2 on: March 31, 2007, 06:39:01 AM »
Sounds like you need a new base plate, IMO I would get a new floyd rose package cause ordering Base Plates takes FOREVER! I ordered one from the only company that sells them and it took.........*thinks*..........about 7 months. And they sent me the wrong color too  :D.
« Reply #3 on: March 31, 2007, 06:41:52 AM »
Yeah, i think i iīll have to order the entire FLyd rose
q:/
Unfortunately
the screw hole,is worned. so, the screw keeps on rolling in circles and not hold it . every move, is enough to move the saddle out of his place,so, that means Bad intonation AT ALL
q:/
someone here said that if i got larger screws,it willsolve the problem
not sure about that
« Reply #4 on: March 31, 2007, 09:51:06 AM »
So basically, the thread for the screws has gone?
The trick I use is, get some wood.
Saw it
Take the saw dust - Combine it with some wood glue, then get a nail, and shove the gluedust in there.
Then screw back into that with your screws ^_^
« Reply #5 on: March 31, 2007, 10:16:01 AM »
Quote from: noodleplugerine
Saw it
I think that something stronger than sawdust and woodglue is required to repair the stripped out metal baseplate.
That trick might work to repair a hole in some wood that is stripped out however
you could try a product like chemical metal torepair the baseplate or you can get just the baseplate bit replaced - that trem is made by schaller and is often called the Floyd Rose II, and spare perts are sometimes available
« Reply #6 on: March 31, 2007, 11:04:22 AM »
Whoops! It's metal?
Proves that I've never had a locking trem :p
« Reply #7 on: March 31, 2007, 11:17:40 AM »
This will not help you now, but in the future:
When turning screws, never add force or much pressure. If you want to make sure a screw is tight, turn it until there is resistance, open a bit, turn a bit further, open a bit, turn a bit further.
Like this you can drill them tight without messing up the screwhole.
« Reply #8 on: March 31, 2007, 03:04:00 PM »
Holy shite,, Thanks for the support hunter and feline
thats what i was looking for
thankīts
Jp
