Quotewhats with the red wires that go no where?
On 4 conductor wire pickups you will still solder connect two of the wires together and insulate them as shown if you are not going to coil tap etc
With Duncan it is the RED and WHITE
With BKP it is
GREEN and WHITEQuote
that random wire coming out of no where saying ground wire coming from bridge... what does that mean?
That is the Earth wire that Philly mentioned- you will see it when you take the pickguard off , and it needs to stay there- so if you have to unsolder it to get at stuff remember to resolder it back on
Quoteam i correct in that i do not have to worry about the volume pot when replacing my pickup?
it seems that all i have to do is solder one wire to the base of the bridge tone pot i guess, and one wire to one of those 3 little things coming out of the pot.
You will notice from the Duncan drawing that you will attach the Bare screening wire and the Green wire which will be the
BLACK one from your BKP to the back of the Volume pot
The "hot" wire or output wire (Duncan uses Black but BKP uses
RED) goes to the tag on the volume pot for that pickup
So you will have 2 volume contols and one tone as per the picture
