Main Menu
New Guitar
Started by Tyrian, April 20, 2007, 08:41:41 PM
Transcend
Quote from: MDVThe miracle man is pretty bright, though, and extra fixes are extra hassle. Its hard to say without knowing whats in there. It may also be that, with the MM being bassy, too, it ballances.
Anyway
Painkiller...?
i took the pickups out for him earlier and they are nbranded no names the bridge does sound really hot for a cheapo pup and has a ceramic type edge to it but cleans up far too well and is far too natural sounding to be ceramic.
I know that this guy likes a big chunk of bass in his tone so i would say warpig personally.
I have no idea on how the painkiller sounds at all so i can not comment on that one.
From a lot of what hes said, I'd say C-Pig, or the warpig would do it, but less tightly. Not that its not tight.
But I think it might rip his balls through is mouth *shrugs*
PK has some great bass on it, apparently.
Transcend
Quote from: MDVFrom a lot of what hes said, I'd say C-Pig, or the warpig would do it, but less tightly. Not that its not tight.
hmm ill make him listen through some more clips
Tyrian
Am actually considering a C-pig atm. I want something clean up, but to be honest, there's 2 pickups, so it ain't much hassle flicking a switch.
But like Tony said, I'll just listen to some more clips and try and find what's best
I'd also like to thank everyone for their help so far.
Jay Turser JT230 - Nailbomb Bridge
Epiphone Gothic V - Soon to have Warpig
Ashdown FA60
Tyrian
Quote from: gingataffMaybe a plain old alnico Warpig with a parallel switch for the cleans.
I'm probably gonna sound like an idiot here. But I've not heard of a parallel switch before. But something that comes to mind that it might be, is coil-tapping. Am I right?
Ashdown FA60
MentalTan
Maybe go with a pickup that has more mids to tame the brightness, maybe Holy Diver, I've also heard that warpigs have a good midrange too.
Quote from: TyrianI'm probably gonna sound like an idiot here. But I've not heard of a parallel switch before. But something that comes to mind that it might be, is coil-tapping. Am I right?
People often get the two confused.
Coil tapping is just what it sounds like: There is a tap placed somewhere in the coil itself which enables you to use either the entire wind of the pickup or just a portion of the winds. Using a coil tap cleans up the sound and lowers the output of the pickup.
Parallel wiring of a pickup lowers the overall output of the pickup, but still uses the full wind. It is often used on a mini switch on your guitar. When you switch between series wiring and parallel you can hear that series has more snarl and bite, higher output, and more bass. Parallel is smoother sounding and has slightly lower output.
And just to confuse things further, people very often say coil tapping when they mean coil splitting.
Coil splitting is switching off one coil of a humbucker to give a single-coil tone.  This again lowers the output of the pickup and gives a thinner, brighter tone which resembles a Fender-style single-coil but is often rather weedy and unsatisfactory due to the humbucker's different magnetic structure.
Coil-split switches are very common on production guitars, series/parallel or coil-tap switches are much rarer.  Personally I like series/parallel because it's a different, useable humbucker sound rather than a poor "imitation" of a single-coil.  And it works particularly well with high-output humbuckers.
Quote from: Philly QAnd just to confuse things further, people very often say coil tapping when they mean coil splitting.
... and the coil's position, I would add.
QuotePersonally I like series/parallel because it's a different, useable humbucker sound rather than a poor "imitation" of a single-coil.  And it works particularly well with high-output humbuckers.
Agreed!
Eric
Quote from: TwilightOdyssey
Parallel wiring of a pickup lowers the overall output of the pickup, but still uses the full wind. It is often used on a mini switch on your guitar. When you switch between series wiring and parallel you can hear that parallel has more snarl and bite, higher output, and more bass. Parallel is smoother sounding and has slightly lower output.
Not to sound snotty or anything TO but did you mean that SERIES has more snarl bite and output instead of parallel.
I agree that parallel wiring is cool and not used enough in guitars.
Tyrian
I shouldn't have asked lol.
I understand now, but I'm sorry for causing arguements.
Reason I shouldn't have asked is that now I have FAR too many options available to me lol.
I'm sure I'll work something out.
Ashdown FA60
If youre willing to wire the bridge with a series/parralel switch of some sort then you can get great cleans out of either pig.
I still think that it might rip your balls through your mouth (in series, at least), since its one of the most powerfull pickups in the world. But its a far more musical sound than most high power pickups. You might like it. I dunno.
Quote from: EricNot to sound snotty or anything TO but did you mean that SERIES has more snarl bite and output instead of parallel.
You are quite right! Temporary brain twist. Original post fixed, and my thanx!
Quote from: TyrianI shouldn't have asked lol.
I don't see anyone arguing here! Just a brisk convo about pickup wiring from where I see it. :)
Tyrian
I well, my brain was on fire, and I'm a blonde (That excuse works for women so I'ma try for that equallity shite lol)
Ashdown FA60
