Quote from: Tim
We do short leg versions of all our pickups-the player who had probs got his off ebay and not us-when you buy direct we check out this sort of thing.
It appears that my problem was nothing at all to do with the long legs of the pickup :shock:
On my Gordon Smith I found that the holes that were drilled for the pickup screw magnets to slot into weren't long enough to accomodate the longer magnets that BK Pups use. I drilled these holes deeper and the bridge pickup is now fitted and works fine :D
The neck pickup however is a different story. I drilled both the screw magnet holes and the pickup leg holes deepr and it made little to no difference. It appears that there's a 2mm 'slab' of wood in the centre of the cavity and the BK pup I installed appears to be 'resting' on this slab of wood and cannot move up or down in the pickup mounting ring.
I bought a Dremel type rotary power tool yesterday, so the slab of wood is soon to be no more and then I can finally get my BK pups fitted and get trying them out :D
Just thought I'd elaborate that it wasn't the long legs of the pup and it was indeed the routing of the guitar that's causing me my problems :)
Craig
