Quote from: PhilKingJust a quick question about the installation. I have a PG blues set, and have also played Tim's, and I thought that the neck pickup was designed to be reversed (like Peter Green's). That's how I did mine and that's how Tim's is. Did he wire it differently for you because of the middle pickup?
Just as an afterthought to that...
Because the neck and bridge are out of phase, and I can dial in the middle p/u independently of the selector switch, this gives me:
Bridge alone
Neck alone
N & B out of phase
Bridge blended with Middle in phase
Neck blended with middle out of phase
N & B together out of phase, blended with Middle in phase with bridge, but out of phase with neck.
Or Middle alone, of course.
Lots of tones to play with, without even a push-pull. In practice because the wiring is not correct, the in-phase sounds are lacking in top, but that aside, this is MUCH more versatile than the original wiring.
