Author Topic: Tuning problems - Sperzel tuners?  (Read 13033 times)
lifted
Grovers
« Reply #15 on: July 04, 2007, 11:06:27 PM »
I would go with the "self locking" grovers that they have.  They will fit with no extra hole drilling.  I liked sperzels until I got a new neck and removed them from old neck and the cheap, soft, metal of the bushings stripped out to where I couldn't use them for the new neck.  The grover mini locking are great, there's no dial to tighten,  you just put the string through hole, start tightening to pitch, and they lock inside.   There is a slot on top of the post to unlock when destringing.  I will try to find you a link if you want
Irish Tour/ Mule Set,    Apache Set... in Strats .... Nailbomb Bridge,Cold Sweat Neck in Ibanez S540
donovan.x
« Reply #16 on: July 05, 2007, 12:08:34 PM »
I have just installed a set of Locking Grovers and they are superb. Easy to install and tuning stabilioty to the maximum. I have had the Sperzals before and they are good but I prefer the Grovers (specially on a L/P)
 :D
DEATH TO ALL BUT METAL!
Crazy_Joe
Re: Grovers
« Reply #17 on: July 05, 2007, 03:21:37 PM »
Quote from: lifted
Sounds good! i would like a link if possible :D
Black Dogs
Transcend
Re: Grovers
« Reply #18 on: July 05, 2007, 03:34:58 PM »
Quote from: Crazy_Joe
Quote from: lifted
theyre what i used to have on my rocket roll and i must say they are probably the best i have ever used. check on ebay they come up quite often.... theyre brilliant for fine tuning as well.
Crazy_Joe
« Reply #19 on: July 05, 2007, 04:38:18 PM »
Are they these ones?
http://cgi.ebay.co.uk/GROVER-LOCKING-GUITAR-TUNERS-SELF-LOCK-MACHINE-HEADS_W0QQitemZ300126670444QQihZ020QQcategoryZ41434QQssPageNameZWDVWQQrdZ1QQcmdZViewItem#ebayphotohosting
If they are i can't see them fitting on my guitar, the screw place is at too much of an angle whereas the ones on there now are basically perfectly horizontal from the tuner.
Black Dogs
« Reply #20 on: July 05, 2007, 04:44:31 PM »
i know everyone raves about these grovers but the one set i have used let me down.  It never locked onto the high e string very well at all and we had to wrap the string round the post like normal to get the guitar to function.
Transcend
« Reply #21 on: July 05, 2007, 05:39:17 PM »
i believe all grovers are at that angle too.
most likely sperzels or wilkinsons will be the only ones that will fit without drilling
lifted
« Reply #22 on: July 11, 2007, 05:50:04 PM »
yes, those are the ones, CrazyJoe.  I am sorry they won't fit.
