Author Topic: Which floating bridge?  (Read 5432 times)
simonp
    • http://www.myspace.com/earlsofstoke
« Reply #15 on: July 24, 2007, 10:45:00 AM »
There is quite a lot of clearance behind the current Scaller, almost as if it was routed to take a different bridge, but it is about 5mm less than the recommended routing dimension for the Floyd Rose one, so not sure if it would fit or not. Unfortunately the dimension to the back of the string locking screws is one of the few dimensions I cannot find for teh Floyd Rose.
Les Paul Standard with Mules, Charvel Fusion, Cornford MK50H & 2x12, Trace Elliot Speed Twin C100.
