Quote from: OliGo for offset dots for the inlays!
noted!! - Still nor sure if it will any inlays at all yet.
This morning i have prepared the neck laminates
above we have two zebrano laminates and a whole bocote bass neck blank. But as you can see the bocotes grain is not ideal for a neck since it is travelling diagonally. If this where a softer/weaker wood like mahogany i would never consider using it for a neck but since bocote is quite stiff it should still be all right in a laminated neck. So i have sawn a stip off the side of that neck blank for use in this guitar. the rest will also be sawn up for laminates
see the colour difference with freshly cut bocote - it starts to darken pretty quickly but is really vomity at first:
and here we have the 3 bits being clamped together:
a few more clamps went on after i took the photo
