Author Topic: Am I crazy  (Read 8702 times)
Am I crazy
« Reply #30 on: October 17, 2007, 05:22:13 AM »
Quote from: callme.nasty
yeah i actually have the level on like 6, tone on 6, and gain on like 8. I know adding to the gain makes it sound worse, but i wanted the extra sustain. anyway, i guess i'll try putting the level on ten and take out the drive. little randy rhoads clean boost?
as for the amp, yeah its some type of hybrid. i'm not really knowledgeable about whats tube and whats not, but originally when i was looking at reviews most people said the distortion channel is just as good as any marshal out there, and i love it. clean channel sucks ball though...
hmmm
low down the gain on the pedal
with the gain on 0 the pedal works as a pickup booster and you won't lose the extra sustain
your tone will sound a lot quieter and clearer
on my last band rehearsal i was getting a lot of noise, feedback and artficial tone
then when i checked the pedal, the gain was on 10
i think i pulled the knob with the cable  :lol:
so i lowered it to 0 and my tone ot a lot better without losing any gain, punch or sustain
just the mud went away
CJ
Am I crazy
« Reply #31 on: October 19, 2007, 01:47:00 AM »
Quote from: gingataff
It's not wired in parallel, is it?
sorry to bring this up again, but what exactly does this mean, and is it a possibility? I've looked at diagrams, and my wiring does not match the traditional wiring. Does it sound like this is my problem?
Am I crazy
« Reply #32 on: October 19, 2007, 12:15:21 PM »
In a standard humbucker the coils are connected in series, which means that from the live the signal goes through one coil and then through the other (in the opposite direction).  When the wiring is parallel, the signal goes through both coils at the same time.  This gives a much thinner scooped sound as the resistance is dropped massively (think about resistors to understand this, if you have 2 100k ohm resistors in series the resistance is 200k ohm, but in parallel it is only 50K ohm).
On BK's to wire in series the signal goes from red to green for coil 1, the green the connects to the white and flows to the black.  Any other wiring will not give the full output of the pickup with hum cancelling.  In parallel the red and white are live and green and black are ground.  Split will either take the red/green or white/black as the only connections.  Anything else is wrong, and will give you strange results.
CJ
Am I crazy
« Reply #33 on: October 20, 2007, 04:22:01 AM »
its two conductor wiring, and i forget how its wired... i'd have to take a pic or something when i get a chance.
also, the ZW OD definitely sounded much better with gain on zero and output on 10! still not quite what i'm looking for, but it gave me all that sustain and pinch harmonics with no insane feedback, none at all actually.
Ted
Am I crazy
« Reply #34 on: October 20, 2007, 10:18:15 AM »
Thats how I use it.
