Author Topic: Pickups for a les paul & a modern strat  (Read 2700 times)
octavio_amzer
« on: October 23, 2007, 10:19:24 PM »
The idea here is that the Les paul should sound on the vintage hot side and the modern strat mmm... must sound modern.
both guitars will be used in Eb standard tuning and BOTH must be VERY versatil players. Playing heavy metal, Jazz and clean fusions.
neck and bridge
« Reply #1 on: October 23, 2007, 10:20:51 PM »
What BKs do you already have? I've been batting 1,000 with suggesting pups that the OP already owns this week!
octavio_amzer
« Reply #2 on: October 23, 2007, 10:47:29 PM »
Quote from: TwilightOdyssey
Miracle Men
Cold Sweats
Warpigs
« Reply #3 on: October 23, 2007, 10:49:03 PM »
Thanx!
Well, for the LP I would definitely go for VHIIs.
For the strat ... are you going to put a humbucker in the bridge?
If so, I would do Holy Diver or Nailbomb and 2x Trilogy Suites.
octavio_amzer
« Reply #4 on: October 23, 2007, 10:50:55 PM »
Thanx!
both guitars use Dual Humbuckers.
what is the difference between Mules and VHIIs?
« Reply #5 on: October 23, 2007, 10:51:58 PM »
The Mule is probably a touch more transparent. The VHII has more grind, but only just.
Re: Pickups for a les paul & a modern strat
« Reply #6 on: October 23, 2007, 11:37:38 PM »
Quote from: octavio_amzer
neck and bridge
Warpigs with parralel switching option  8)
carlaz
« Reply #7 on: October 25, 2007, 03:56:07 PM »
The idea here is that the Les paul should sound on the vintage hot side [...] must be VERY versatil players. Playing heavy metal, Jazz and clean fusions. neck and bridge.
I'm gonna jump in and recommend Crawlers for the LP: vintage-hot, like the Abraxas, but with a bit more mid-bump in the bridge pup to cut through the mix, and very versatile from clean jazzy tones up through roaring metal. I remember Tim saying that he sells lots of Crawlers to working, gigging guitarists who need a wide-ranging pickup that sounds great across the range.
http://soundcloud.com/carledlundanderson
