Author Topic: 24 fret telecaster?  (Read 14468 times)
Muso
24 fret telecaster?
« on: October 24, 2007, 12:02:18 PM »
hey guys
I currently have a Fender HM strat which I love but I am kinda wanting a new guitar. My idea is basically a 24 fret telecaster, Ive been looking around but I've not had much luck. Fender made a guitar called a "blackout" which looks like it might do the job but theyre really hard to find in the UK.
I was possibly thinking of just buying a telecaster body and 24 fret neck separate but I dunno would this work or would I end up with terrible action and other problems. my dream is to have a sunburst telecaster body with a 24 fret fender HM strat maple neck, JEM frets, and a Nailbomb in the bridge with two trilogies. I think this would be a pretty cool unique guitar but dunno if it's possible or not.
Any ideas would be great, cheers!
Antag
24 fret telecaster?
« Reply #1 on: October 24, 2007, 12:14:17 PM »
Theoretically you can get a Warmoth Tele neck with 24 fret extension.  However there are a few problems with it:
1. It would cover the neck pickup, so you'd need a non-standard pickup rout
2. Access to the top frets would be very poor (the neck joins the body in the same place)
In other words, it's technically viable but would be practically useless & look odd.  JMHO, YMMV etc...
Muso
24 fret telecaster?
« Reply #2 on: October 24, 2007, 06:42:22 PM »
Thanks for the reply.
So its gonna be a real mission to do, would a Fender Hm strat neck not just be able to fit onto it then?
I'm contemplating just getting a fender blackout telecaster:
http://www.musiciansfriend.com/product/Fender-Telecaster-HH-Blackout-Guitar?sku=511340&src=3SOSWXXA
Looks kinda cool but it isn't really anything like a telecaster which is defeating the object of getting one.
Mr Ed
24 fret telecaster?
« Reply #3 on: October 24, 2007, 06:46:08 PM »
Quote from: Muso
Played one. LOVED it, the Pearly Gates works so damn well and it looks different.
24 fret telecaster?
« Reply #4 on: October 24, 2007, 06:50:09 PM »
The strat neck may fit (I don't know personally)
but scale length, the 12th fret has to be half way down the string length
so half of 25 1/2 inches is where the 12th fret should be sitting.
Adam.M
    • http://www.healeyamps.co.uk
24 fret telecaster?
« Reply #5 on: October 24, 2007, 08:01:03 PM »
Couldn't you just add a 24 fret neck and move the bridge to compensate?
On a warmoth without the bridge pre-drilled...
24 fret telecaster?
« Reply #6 on: October 24, 2007, 08:04:27 PM »
Quote from: Adam.M
That would change the scale length and f*ck things up - the distance from the nut to the 12th fret should be the same as the distance from the 12th fret to the bridge.
 :twisted:
Antag
24 fret telecaster?
« Reply #7 on: October 24, 2007, 08:08:09 PM »
Hard to say.  Most strat necks will fit a Tele neck pocket (but not the other way round), but IIRC the HM strat had a non-standard neck pocket which isn't compatible.
As Will correctly points out (& this Warmoth page also explains), if the screw holes on the 24fret neck are at different points relative to the frets (e.g. under frets 19 & 22 instead of 17 & 20) then each fret will be further from the bridge than with the 22 fret neck, the scale length will be more like 26¼" & the guitar won't intonate correctly.  So no, the HM strat probably won't fit a Tele body...
24 fret telecaster?
« Reply #8 on: October 24, 2007, 08:48:09 PM »
You cant put a 24 fret neck on a 22 fret body - wont work
You would have to have a body that is cut for 24 frets which means the bridge will be in the right place
Also watch out - I believe that HM strats are not Fender scale!!
They have a shorter scale length!! About 25"
the blackout tele looks way cool
Muso
24 fret telecaster?
« Reply #9 on: October 24, 2007, 09:17:22 PM »
Cool information, sounds like a total pain in the arse to get so I think I'll just try and get a blackout. Theyre not made anymore does anyone know anywhere which I might be able to get one?
Davey
24 fret telecaster?
« Reply #10 on: October 24, 2007, 09:21:01 PM »
Quote from: FELINEGUITARS
only the warmoth necks can be used on a 22 fret guitar, to get 24 frets. they are built the same as a 22fret neck, they just have a 2 fret extension over the butt of the neck.
and yes, the HM strats were 25' scale
24 fret telecaster?
« Reply #11 on: October 24, 2007, 10:48:05 PM »
Quote from: Davey
Are you sure you mean 25' and not 25" :cry:
24 fret telecaster?
« Reply #12 on: October 25, 2007, 09:41:01 AM »
Quote from: Davey
i can imagine the spinal tap-style c--k up in the feline workshops ;)
Re: 24 fret telecaster?
« Reply #13 on: October 25, 2007, 02:29:50 PM »
Quote from: Muso
Don't know how well it fits with your plans/budget, but Carvin do a 24-fret Tele, the TL60, with all the options you could ever want:
http://www.carvin.com/gallery/guitargallery.php?ItemNumber=TL60
http://www.carvin.com/products/guitar.php?ItemNumber=TL60
Muso
24 fret telecaster?
« Reply #14 on: October 27, 2007, 12:05:19 PM »
Carvins a bit out of my price range and I really like the idea of owning a Fender made telecaster, thanks for the info tho.
I'm currently looking at getting one of those fender blackout telecasters off ebay but I'm worried about getting burned. My current guitar was a Fender Hm strat from the USA and you should have seen the state it came in, nothing like in the photo I had to spend a packet to get it up and running.
If anyone knows anywhere with a fender tele blackout for sale give me a shout!
 :D
