Pedalboard
Started by noodleplugerine, October 25, 2007, 10:08:33 PM
AngusYoung01
I say sod everything, and save for a TC Electonics G-System  :D
Or get pedals you need  :lol:
Quote from: AngusYoung01I say sod everything, and save for a TC Electonics G-System  :D
I was contemplating buying a G Major and a midi pedal board - But we'll see :P
AngusYoung01
I really want that G-System, just looks so good, and seems to do everything!
I just have one question, I don't know if anyone here knows, but I think I read somewhere that it can hook up to the footswitch jack socket on the amp, and change channels, so like,  you can store channel changes in the presets. Is this true?
If it is, I'll need to get one  :)
Quote from: AngusYoung01I really want that G-System, just looks so good, and seems to do everything!
Only if you have a midi amp surely.
So, any Diezel, all the top ENGLs, the VHTs, I think some Mesas, alot of more hi-tech boutique amps.
AngusYoung01
Oh  :( I thought you could just hook a standard jack from one of the inputs to the socket for the footswitch. Its a MArshall DSL I'm using.
Another thing to knock off the list, just bought a Behringer BTR2000 racktuner on Ebay, has a metronome function aswell, I think this'll be a half decent buy, even if it turns out to be tone sucking.
Just won a 10 output power supply and a Bad Horsie.
Only the Small Stone, the Sonic Maximizer, and the SD-1 left!
Oli
I think the G system does have jack switching, so you can switch amp channels.
Quote from: OliI think the G system does have jack switching, so you can switch amp channels.
Not if the multi-channel amp has only 1 input, surely?
Or could you put the G-System as a amp channel foot-switch via a normal jack cable?
crimesofpassionandy
The G system switches amp channels using a standard guitar cable, not midi. I've just ordered mine at the weekend, woohhooo!!!
Quote from: crimesofpassionandyThe G system switches amp channels using a standard guitar cable, not midi. I've just ordered mine at the weekend, woohhooo!!!
Ooooh la la
This thing seems to be pure magic!
AngusYoung01
Quote from: noodleplugerine
Ooooh la la
It really looks more and more tempting... first I need a guitar with a trem though!
Quote from: AngusYoung01first I need a guitar with a trem though!
blasphemy :P
Ooooh la la
"first I need a guitar with a trem-o-lo" ?  :D
maverickf1jockey
Ooooh la la
That's spelt 'vibrato' or 'whammy'. 'Tremolo' is volume based.
