Author Topic: Need wood help  (Read 2171 times)
octavio_amzer
Need wood help
« on: November 02, 2007, 06:35:56 AM »
would a 3 piece maple neck neckthru
sound good with Korina body wings in a V?
how would this sound in theory?
Need wood help
« Reply #1 on: November 02, 2007, 07:14:29 AM »
If its a neck through the main tonal contributor will be the neck section.  So at first i would think it would be a little bright - but the wings do have an effect and would soften it somewhat.  Personally i would use something else for the middle laminate in the neck - probably mahognay or korina
Hard to know for certain without tapping the exact pieces of wood you will use
octavio_amzer
Need wood help
« Reply #2 on: November 02, 2007, 08:59:46 AM »
hey... that's a very good idea..
how would it sound if there was Korina running thru the middle of the 2 maple pieces and the rest of the body Korina with ebony fretboard?
Need wood help
« Reply #3 on: November 02, 2007, 09:21:03 AM »
as always its hard to be exact but the maple/korina/maple neck will give clarity whilst ovoiding over brightness - and paired with the korina wings should be quite balanced without the tendency for over brightness you get on solid maple guitars.
The ebony board affects things a bit as well, more the attack of the note - personally i would go with rosewood for a bit of warmth/softer attack, but thats down to taste.
but with the woods you are using its hard to get a bad sound anyway so dont worry about it to much
Need wood help
« Reply #4 on: November 02, 2007, 03:11:50 PM »
i have a 5-piece mahogany/maple/ebony/maple/mahogany neck-thru V with mahogany wings and a maple top, and an ebony fingerboard. It sounds badass.
Need wood help
« Reply #5 on: November 02, 2007, 04:59:25 PM »
well badass is definately what we are all aiming for :P
When you are using common guitar woods like this  and mixing them up a bit the only important thing to think about is getting good quality stuff from a reputable supplier and it should turn out fine..  If you have more specific tonal goals things get a little more complex
Korina should work for a laminate in the neck section if you can find a nice straight grained piece that is either quarter or flat sawn  - not inbetween.  I have made korina necks before and they work great  but i havnt done a through neck with it and it might be harder to source a piece that has a good enough grain along the whole length of the guitar
Need wood help
« Reply #6 on: November 03, 2007, 05:02:31 PM »
^ haha, yeah. at the end of the day, badass is what you want.  :lol:
Pierre
Need wood help
« Reply #7 on: November 03, 2007, 05:15:51 PM »
I have a maple neck through with Alder guitar and it's not very bright. Got an OFR on it too. Sounds gorgeous if anything. Tight and defined sounding. I prefer the usually snappier, somewhat more aggressive tone of bolt ons mostly though.
Need wood help
« Reply #8 on: November 03, 2007, 05:49:09 PM »
thats always the way - i have tried to stress quite a lot that these are only ever generalisations.
the truth is that wood will vary in grain structure and density incredibly even within the same tree, let only between trees and even different types of the same species of tree.
For most people this is solved by trying out lots of guitars till they find one that suits them.  For people that build guitars for customers with specific tonal requirements it gets a lot harder because you have to know what to expect from a piece of wood.
You start with general species that should give you what you are after then go through lots of wood to find a piece that you think will meet the requirements closer.
For example.  I am making a through neck SG at the moment and we decided to have a laminated mahogany neck through.  That tells you a certain amount about what we were after.  i had two mahogany neck through blanks available - both exactly the same size, both with a good grain structure and perfectly usable.  One of them weighed 2.5kg  one weighed 4.5kg.  therefore its nearly twice as dense and that would have had a profound affect on the way the guitar sounded.  we decided on the lighter one because weight is also an important factor when choosing wood.  And i think it has a tap tone that will suit the customer better
my point is that we can go on about how wood will sound in theory till the cows come home but it all goes out the window once you have the actual raw materials.
If anyone is aiming to make them selves a guitar dont let this put you off - like i say, you cant go far wrong with good quality materials
