Jackson rr1 and pickups
Started by bronz79, November 08, 2007, 12:49:03 AM
bronz79
Hi! i've got a jackson rr1 (adler body, construction neck through, ebony fingerboard) and i'm plannig to replace the stocks pickups (SD jazz and jb)
my ideas are:
a calibrated set of nailbomb
or
miracleman at the bridge and cold sweat at the neck
I want something perfect on the cleans and fluid solos for the neck
and something aggressive but organic for the bridge.
octavio_amzer
good cleans and fluid solos = Cold Sweat neck 4 conductor
aggressive and organic on bridge = Nailbomb bridge, 2 braided or 4 conductor will do.
The Emperor
Quote from: bronz79Hi! i've got a jackson rr1 (adler body, construction neck through, ebony fingerboard) and i'm plannig to replace the stocks pickups (SD jazz and jb)
my ideas are:
or
Welcome to the BN forum!
I also have an RR1 now loaded with the NB... with (ofcourse the same specs.) but it came with Bill Lawrence as stock pickups. First i need to know which type of amp you use and which type of metal, hardrock you play... before i answer this question?. Tim told me that the NB would work great in the RR1 and it did!. Crunchy, awesome cleans etc  the NB pickup eat the stock Bill Lawrence for breakfast :) though i still have the Bill left in the neck.
/E
W
Engl Savage 120
Engl V60 cab slanted
Jackson Death angl
Jackson RR1
Quote from: octavio_amzergood cleans and fluid solos = Cold Sweat neck 4 conductor
Good shout. +1
bronz79
Thank you for the answers!
For my guitar is better suited the long leg baseplate 1/2" or the short 1/4"? i think the short but i'm not sure.
I think i'll buy the nailbomb for the bridge 'cause AlnicoV has better
dinamic but i'm still undecided between a nailbomb calibrated set or
a cold sweat at the neck to match it.
Antag
Get the short leg, but also ask for triangular feet (they're not an option on the shop page, put "triangular feet" in the comments box) - all the Jacksons I've BKP'd had quite a small rout that the square feet didn't quite fit.
If it's under a mounting ring you can just widen the hole by ~½mm with a dremel without altering the external appearance, but you might as well save yourself the trouble & get BKP to make a pickup with feet that will fit :)
bronz79
Quote from: AntagGet the short leg, but also ask for triangular feet (they're not an option on the shop page, put "triangular feet" in the comments box) - all the Jacksons I've BKP'd had quite a small rout that the square feet didn't quite fit.
thank you for the advice, but the stock Seymour Duncan doesn't have the square feet? :oops:
Antag
Well, the stock Duncans in both my RR1T and my Kelly had feet that were either triangular or slightly rounded at the corners & fitted flush to the routed hole, so square BKP foot didn't quite fit.
Safest thing is to unscrew the pickup bezel on your guitar & have a look, I'm sure Jackson have routed different sized holes at various times in their history...
Antag
By "feet", I mean the part that the mounting/height adjustment screw goes through.  to look at it you have to unscrew the pickup bezel/mounting ring.
The Emperor
Tell us your first impressions on NB when you get it  8)
Engl Savage 120
Jackson Death angl
Jackson RR1
bronz79
Quote from: The EmperorTell us your first impressions on NB when you get it  8)
for sure! I'll order them this week but i think must wait ten days before
i'll recive them  :roll:  :)
if a holydiver is similar to a SD JB, a nailbomb instead?
The Emperor
You will be plugged in with the nailbomb. My RR1 was under the bed for a long time and since i installed it i'm riffing like the guitar was new  8)
/E
Engl Savage 120
Jackson Death angl
Jackson RR1
bronz79
 ....time has passed pretty quickly! :)
For my RR1 i've ordered a cold sweat for neck and a MM for bridge in january 2008
Awesomeness..both!
But i've changed 3 amps in the meanwhile.
-Powerball
-VH4
-now i'm using the Herbert. :D
..and now i'm a bit thinking about changing bridge pu.
I like cold sweat at all so i don't want to change it i like also MM but there is any BKP bridge pu with those specs?
-tight and not boomy bass..maybe a bit more growl on bass section and palm muting
-midrage grind (i use midcut on the Herbert and MM has not to much midhighs)
-High..i like MM high in the Herbert in the VH4 they where a lot piercing
-I play in D Necrophagist like stuff..so articulation and note definition is a must.
-not too compressed on a Uber gain amp.
Thanks. :)
Antag
Quote from: bronz79 on June 08, 2010, 04:39:49 AM
This .... is ... the Painkiller :twisted:
(I have a PK bridge with CS neck in my KV-2 & it slays :))
ratspeak
This ^
I was going to say... but I've been making recommendations all over today and I have zero credibility, so I thought I'd back off for a bit.  :lol:
