Main Menu
Semi problem
Started by Sailor Charon, November 08, 2007, 05:35:57 PM
Sailor Charon
Well,  to cut a long story short, I've managed to knock the jack on my AV3, and it's slipped inside. Am I stuffed, or, when I (get someone to) change the pickups, will it be possible to sort it then. [At the moment, I'm just not plugging it in]
Thanks folks.
I'm sorry, but that post made no sense to me!!
Quote from: TwilightOdysseyI'm sorry, but that post made no sense to me!!
From what I can tell, the output jack of the guitar has been pushed inside the body.
headtheball
you need one of these
Don't suppose you have a mate works in a lab or a school science department?[/url]
Evil, Evil, Evil...
Sailor Charon
Quote from: _tom_From what I can tell, the output jack of the guitar has been pushed inside the body.
Yes, that's what I was trying to say. It's a semi-acoustic, and the jack is sitting inside the body.
And, alas, I don't know anybody in a school science lab...
Semi as in 335 type or as in acoustic with a pickup?
Dont recognise the code AV3
If it is an acoustic then you can stick a knitting needle or long chopstick through the hole and thread the jack onto it and wiggle it back out through the hole.
If it is an f hole guitar then a simiar cuning plan is required to get the jack back in place .
I often use a 5mm allen key that has a ball on the end to thread through the socket and feed it back through the hole. then I can feed the nut and washer back into place while the jack is held steady by the allen key
Sailor Charon
Quote from: FELINEGUITARSSemi as in 335 type or as in acoustic with a pickup?
It's the 335 copy from Vintage - in their Advance range. I started to worry that I'd come down with dyslexia and mangeled the code, so I looked it up  on their website.
Thanks for the advice, by the way. I'm planning on putting some PG Blues in them soon(ish) so I'll ask the guy who fits them to do it. And, if he acts like I'm asking for a stoat (in a bun, with chips) then I'll  have to have a go myself. I've got an allen key somewhere...
Jonesy76
Do yourself a favour..........
If you're going to stick PG blues into that guitar, gut the wiring at the same time as it'll be lousy Chinese stock wiring made out of the cheapest of all cheap components.
I'm rebuilding my Washburn 335 at the moment with new humbuckers, and a full Historic spec wiring loom.  Pics to follow hopefully in a few days
Sailor Charon
Well... I had a go, and it took me about five minutes. So, thanks folks.
blue
Quote from: Sailor Charonif he acts like I'm asking for a stoat (in a bun, with chips)
Fabulous image!  i think you get "post of the year" award for that alone!  although maybe you should've added coleslaw...
