Author Topic: Good evening - Squier guitar within!  (Read 3753 times)
machine_of_god
« on: November 17, 2007, 07:10:30 PM »
Good evening gentlemen (and the rare lady)   :D
I am a long-time troller, first time poster. Though my BKP's are not yet in my guitar, I can now consider myself part of the gang.
But I digress! On to the meaty bits...
I just got done reading the topic about cheap, beginner guitars, and how Squiers are ghastly. I don't want to start a flame war or anything, just tossing my 2 cents on the table   8)
About 6 months ago I purchased a neon-pink Squier Bullet Strat (plywood body+neck. Yes, you read it correctly. Plywood) because I wanted a guitar to massacre with my newbish mod talents. €120. I had ordered the Red-Silver-Blue Lace Sensor package prior on eBay, costing me another €110.
I removed the strings and kept them (good quality cuz the guitar was restrung at the shop when I purchased it). I would later put them back on as there was plenty of extra string to pull through the tuner holes cuz whoever restrung the guitar left like 7-8 turns on each post. Lucky me    :wink:
First order of business; toss those tremendously shitee pickups out the nearest window.
Surprisingly, the cavity was shielded with some silvery tape stuff. Cool. Checked the wiring; pretty solid. The wires themselves weren't really top-shelf, but as I later discovered, they were sufficient.
I also discovered that the Lace Sensors were larger than the original pickup holes, so I had to sand them out. Took a bloody long time cuz all I had was some pretty fine grit sandpaper available.
Finally I squeezed in the Sensors, wired them up, and checked all connections with a multimeter thingy I also found in a closet. All the grounding was proper, all the connections were unbroken. Great.
Very quickly drilled a hole in next to the pots, randomly chosen location. There I installed a "neck-on" switch. This I wired accordingly so that when activated, the neck pickup would activate despite the position of the 5-way.
Then I re-attached the scratch plate then set to work on the saddles. I had also appropriated a set of Graphtech String Saver saddles (those black things) previously, so those went on without a hitch. Accordingly, I ripped out the old, horrid plastic nut and replaced it with a Graph Tech Trem Nut (same black stuff). Reattached the strings (cuz I'm cheap).
So the strings were now sitting on very slippery stuff, with a magnetic field from the pickups that - apparently - doesn't really pull on the strings much at all. Very good.
The tuners on the headstock were/are incredibly solid. The ratio is a bit unrefined, but they hold steady. Actually, of all my guitars, this guitar is the one that requires the least retuning.
Anyway, to wrap it all up, I plugged it in and checked to see if the pots and 5-way switch made any scratchy noises. Nope, they're fine. They're cheap, but they're fine, cuz I use everything at 10 anyway. The Laces sound marvelous. Good heat on the red bridge, the middle silver sparkles like freshly Windex'ed glass, and the neck blue has a pretty nice, fat tone while keeping that single-coil charm.
And my favorite part after this extraordinarily long-winded and most likely boring essay... is that the guitar sounds like it should be worth 5 times what it cost. The thing sustains very nicely thanks to the Graph Tech stuff (imagine how it would perform with a proper tone wood...), and when I have the bridge selected on the 5-way, with the neck-on switch activated, I get a sound which is as close to a telecaster twang as makes no difference.
Practiced with it alot, gigged quite a bit, and it's fine.
Ok, so I'm not looking for kudos or bashing. Just maybe looking to see if anyone else has done something similar, and is sitting at work, bored, and wants to share.
EDIT: I'll put up some pics of it once I get home, if anyone is remotely interested in looking at a very girly guitar  :P
BKP guitars:
Epiphone Dot Studio (NB bridge, MQ neck)
Gibson LP Studio (MM bridge, CS neck)
« Reply #1 on: November 17, 2007, 07:55:11 PM »
Something I've allways considered doing actually.
Got a Epi SG with 3 pickups.
Considering sticking an OFR and some EMGs in it for a laugh.
« Reply #2 on: November 17, 2007, 08:26:21 PM »
That would mix quite well with the all 3 pickups selection wouldn't it?
happy story though, I have a Stagg flying V with a single Holydiver + vol
Also set the guitar on fire and dented it with a chisel :D
machine_of_god
« Reply #3 on: November 17, 2007, 08:40:06 PM »
And here I thought I had done a lot of modding. Will took it THAT little bit further  ;)
BKP guitars:
« Reply #4 on: November 17, 2007, 10:35:45 PM »
How much could I get for a flamed plywood top flying V eh?
Oh, and sperzels too
brought the guitar up to par with Epi ZW really, no masterpiece, but is alrightish
« Reply #5 on: November 18, 2007, 12:50:15 AM »
I got an Epi Explorer and gutted the electronics...
* CTS pots
* switchcraft toggle switch
* BKP Nailbomb (soon to be Black Dog)
* Duncan '59 (neck)
The fret ends were really sharp and slashing my hands to bits.  Got a basic fret dress and setup now it plays like buttah (easiest to play out of all my guitars)
 :twisted:
blue
« Reply #6 on: November 18, 2007, 03:18:31 AM »
Quote from: noodleplugerine
surely, with the trouble it takes to install a Floyd, you'd be better just getting a guitar with one already installed? and with an SG, due to the thin body, you'd have to grind something off the trem block, making it even more awkward, and costly!  i reckon what you want is one of those Vintage (brand not age) strats with 3 P90's, and then look to add a Floyd, or even a Wilkinson Trem.  i know Tony Iommi uses a Floyd loaded SG, but he can afford it!!
« Reply #7 on: November 18, 2007, 08:39:15 AM »
you peeps should see my first guitar - well technically its just the body thats left and thats been carved into quite a lot.  Started life as a squire strat - not sure what it is now, or where it is for that matter.  I left it at school for people to muck about on and apparently its been sprayed red since then because they needed a red guitar for a school show
machine_of_god
« Reply #8 on: November 18, 2007, 10:16:03 PM »
Not that anyone should be interested in a Squier Bullet Start (ewww) but here is a pic of the scratch plate with the Graph Tech String Saver saddles, the Lace Sensors, and the "neck-on" switch.
Oh yea, I rewired the middle tone knob to control the bridge tone too...
BKP guitars:
« Reply #9 on: November 18, 2007, 11:32:03 PM »
And it's PINK!
machine_of_god
« Reply #10 on: November 19, 2007, 02:33:46 AM »
Hell yea it is!  ;)
I use it when I play gigs for the pop band of which I'm a member. It fits  :P
BKP guitars:
