Power supply 'hum' with booster pedals?
Started by Twinfan, November 19, 2007, 10:04:22 AM
Anyone else have this problem?  If I use a regular power supply on my booster pedals I get a really loud hum, it's worse the higher the boost.  I guess I need to get myself a better power supply?  Are all boosters like this?
badgermark
You need a proper regulated power supply, otherwise they hum like beehatches. Most power supplies from multi-effects aren't regulated and hum like mad.
samoth2
Aren't you guys supposed to be at work?   :wink:
badgermark
I have a break between lectures :P. Got an hour before I have to turn up to learn about photochemistry & photophysics. Glad I have a laptop and a speedy wireless connection provided by the uni  :wink:
samoth2
I wish I had a laptop.
Then school would be so much more fun  :lol:
I'm at work, just not doing any  ;)
OK - regulated power supply it is.....
I recently got a power conditioner, and that made a huge difference to the noise issues I've been having with my amp. Might not help an iffy power supply for a pedal, but certainly can't hurt! It's really dropped the noise floor, which is obviously a big problem for me as I use a lot of gain. Thoroughly recommend these:
http://www.maplin.co.uk/Module.aspx?TabID=1&ModuleNo=46830&doy=19m11
Roo
Henk
Quote from: TwinfanI'm at work, just not doing any  ;)
Yeah me too, i am working for myself though  :oops:
I have the same thing, but then they also make alot of noise when not activated, dont have a clue what is wrong with them, but i have tried every possible adapter, also PSA ones and nothing matters.
They are both old effect pedals, so maybe its just some cap or pot thats making the noise. Would that cause noise if the volume pot has gone bad? would be logical i think. Neiter of my effect are true bypass btw.
I've tried with two of my boosters, both pretty new pedals.  Same problem.  It must be something to do with the power supply and the level of boost that also boosts noise.....
I didn't actually buy my power comditioner from Maplin, btw, just knew I could get a link from there nice 'n' easy :)  Either way, I can personally thoroughly recommend that one!
Roo
the_bleeding
heres how i do it...
i use a one spot for a power supply for 5 of my pedals, but as you kno, its a really basic DC adapter, and plugged straight into the wall you'll get alot of noise. So instead, i plug it into my power bar (which is rectified and has surge and noise protection) and the noise is gone. Monster makes GREAT noiseless power supplies for everything --> makes your TV even look better, stereo's clearer, my friend's xbox doesn't lag as much hahahah.
martinw
Go here http://www.rapidonline.com
and look at this  part number 85-2942.
As sold by Diago pedal boards. http://www.diago.co.uk/pedal-power/pedal-power/
You need to change the polarity, but if you can solder and put a bit of heatshrink on, job done.
I've been using one for over a year with no problems.
Velcro rules!
Custom Built Amps:
www.mjwamps.com
Thanks "mate"........!  Was going to email you about it later.
And velcro clearly does NOT rule  :lol:
Henk
Quote from: Henk
I have figured it out finally, it was a bad (broken?) cable that somehow turned only some effect microphonic, the Boss ones didnt get microphonic strangely.
