Quote from: JDCif I have say 100W head with a 200W cab, will this be the same volume as say a 50W head with a 250W cab?
essentially what speakers do is transform electric power into sound power.
all the matters is the input electrial power, and the efficieny of the speakers at performing the transformation.
the wattage rating of the cabinet refers to how much input electrical power the cabinet can handel without damage. it doesn't affect volume.
efficiency of the speakers is the 'sensitivity' measurement in decibels. decibels are a non-linear scaling. 3dB translates to twice as much. decibels are used as human hearing is also non-linear in a similar way.
a 100W head with a 97dB cabinet will be as loud as a 50W head with a 100dB cabinent.
Quote from: JDCI know wattage and volume are ment to be related but I've seen solid state and hybrid amps with crazy amounts of watts hence, me = confused
many hybrid amps have a solid state output stage, so for the purposes of this point, its kind of the same.
valve amps can produce crazy power too... but they'll need lots of very big valves, and a huge output transformer. it would generate alot of heat, and be somewhat heavy and impractical.
solid state amps don't need an output transformer, and operate more efficiently meaning the engineering challenge of getting big power is easier.
however the power rating of guitar amplifiers is given with an undistorted sine wave...
valve amps will produce more output power when the guitar signal gets distorted, and they sound good at the same time.
solid state amps have hard clipping after maximum output is reached, and don't sound good.
thats why many people talk about 'valve watts' being louder and so on... its not really true at clean levels, but with overdrive then its a different story.
Quote from: JDCand do solid state amps get damaged without a speaker load?
it depends ;) often not though
