Stormy Monday humbucker
Started by 3fingersawayfromahand, November 27, 2007, 07:03:56 PM
SO WHAT does evey one think of them?? and what sorta sound do u get out of them?
Fourth Feline
Well I like mine very much !
They started life in my Les Paul Standard, where they really brought a sweet clarity and definition over the stock pickups. As I wanted contrasting ( but still   vintage ) BKPs for my S.G. also, the S.Ms ended up in my S.G. standard on Tim's recomendation - and they sounded even more suited to the lighter body. To clarify what I mean, I feel that Les Pauls sound more 'Les Paul' with a slightly hotter pickup and a mid range 'hump' . For this I chose the Mules.
Anyway, back to the S.Ms  :D
You will get a very evenly balanced sound, no pronounced emphasis on either treble, mid or bass strings. What you do get is a lovely clear, bright  and articulate presentation across the strings with perhaps some sag or softness in the bass strings. The treble manages to be both articulate, yet not harsh if  the bridge is pushed. With a matched pair in an S.G. it lends itself to the B.B.King, Albert King or T.Bone Walker tonalities - especially with both pickups on together. I can imagine it can handle some classic gain sounds, but I have not had a chance to 'open them up' with a gainy amp yet.
( I do tend to play clean and mellow through Fender or Laney 6L6 type amps or a Peavey Classic 20 with EL84's ). This is where I think S.Ms excel.
I would expect that the overall effect with gain would be soft and sensuous, as opposed to grindy and chunky.  Clear they are, but 'Metal' they aren't. They respond to playing dynamics nicely, sounding mellow or  quite 'spanky' according to picking pressure.
Perhaps initial impressions of the sweet, even, articulate nature of the S.Ms are best summed up by my mate who tried them in my Les Paul. He had a play, and said :
" I realy like these pickups, but if I had them, I'd have to actually practice "  :lol:
Scotty477
Practise?   :guitar4:
Well that rules me out of Stormy Mondays ....  :wink:
I think Derek has given just about as full a description as you'll ever need.  :)
I only have a neck SM (alnico II), haven't tried the bridge model, but clarity, sweetness and articulation are indeed the words that spring to mind.  The pickup seems best suited to clean or just-breaking-up tones; I find it quite hard work to get a really singing distorted tone, but that's probably my lousy playing.  Or maybe it wasn't the perfect choice for the guitar (a very lightweight V).
For my own taste, I must say I'd like a slightly darker, thicker tone with a little more power and a bit more push in the midrange.  I suspect the Mules would give me that, and they'll probably be my next set of BKPs.
I have a set of unpotted AII Stormy Mondays in a 335, an AIV in the neck of a Les Paul and a set of PG Blues in another Les Paul (the PG Blues are Stormy Monday based).  I like the sound of them a lot.  They are a little more single coil sounding than the other humbuckers and excel at clean tones, but when you crank up the gain they can really sing - think Supernatural with Peter Green's sustained opening note.
I also think they are great in the neck position with a hotter bridge pickup, in my Les Paul I have a Riff Raff in the bridge.
I think that this topic has been done to death and is wasting necessary bandwidth.
Using the forum's SEARCH function, BK's own explanations of each pickup, as well as the plethora of clips available, should help you to narrow your search down.
