Author Topic: Monte Allums Mods  (Read 4311 times)
Monte Allums Mods
« on: December 04, 2007, 07:29:10 PM »
Just drilled the hole for the Tri Gain switch on my MT2 sustainiac mod, and finally had a chance to test it out.
These things sound great.
Props to Monte Allums, if anyone reading this is thinking about it - Stop thinking, and order!
The Sustainiac is great, and combined with the tri gain switch, you can actually create quite a few sounds - Through the LEDs it sounds tight, and through the diodes it sounds very dark and high gain - I'd say that the diodes are closest to the original MT2 sound, but at a much thicker, and clearer tone.
Only issue I have is that different settings on the Tri gain switch are at different levels, now I know this sounds obvious, since it's 3 different gain levels, but when put through the diodes it sounds alot quieter volume-wise than through the LEDs or bypassed - But I'm going to relook at my soldering, because I think there must be an error somewhere there.
Overall the pedal sounds better in everyway - clearer, quieter, more definition, more tone. The pedal now has mroe top end, the mids aren't so dominant, although the lows still sound great on the Diode and bypass modes. There's also much less gain - If you want a better quality MT2 then go for the other mod, the sustainiac definetly reduces the amount of the gain the thing has - albeit not by much - in order to improve the versatility of the pedal, I'd say that this could be used as an OD, which the original MT2 had far too much gain for on any setting.
I also did my Monte Allums CS3 Opto Plus mod on Friday, and that too is flawless, very quiet, barely sucks any tone, and sustains brilliantly - everything you want from a sustainer.
Crazy_Joe
Monte Allums Mods
« Reply #1 on: December 04, 2007, 09:24:02 PM »
Awesome, i got a Monte Allums modded SD-1 and it slays!
Black Dogs
Monte Allums Mods
« Reply #2 on: December 04, 2007, 09:33:35 PM »
I have the CS-3 and the BD-2 mods (the BD-2 will make you swear when you fit it, though the results are well worth it). For $20 they are the cheapest pedal upgrade around.
Elliot
Monte Allums Mods
« Reply #3 on: December 05, 2007, 12:05:41 PM »
I have these:
DS1 tri-gain rectifier mod
TS7 to 808+ mod
Both very nice and turn these easy to get  cheap on ebay pedals into monsters.
Ted
Monte Allums Mods
« Reply #4 on: December 05, 2007, 12:17:28 PM »
I've always had time for Monte's work. Great stuff.
I don't have any modded pedals though as I build my own byoc stuff.
Monte Allums Mods
« Reply #5 on: December 05, 2007, 05:45:06 PM »
montes mods are cool, and he seems like a nice guy. i have:
GE-7 (perfect)
CS-3 (perfect, what a difference - standard pedal is utter trash)
SD-1 (with a shite load of other special gwem mods)
TS-5 (not perfect but very nice and cool mod anyway)
DS-1 (not my thing - want to sell it)
Monte Allums Mods
« Reply #6 on: December 05, 2007, 06:42:12 PM »
Quote from: gwEm
GE-7 (perfect)
SD-1 (with a shitee load of other special gwem mods)
I'm curious what your SD-1 mods are, I've done a fair amount of modding on mine and it'd be good to compare.
 :twisted:
gingataff
  • NBVHIIMMPKAHITTSSH
    • My YouTube Channel
Monte Allums Mods
« Reply #7 on: December 06, 2007, 12:31:52 AM »
Quote from: HEAVIER THAN HELL
Quote from: gwEm
GE-7 (perfect)
 :twisted:
Be careful if you also plan on "sharing" Allums' mod info, he's very protective of his ideas:
http://www.monteallums.com/copyrights.html
I see a rainbow rising
Look there on the horizon
And I'm coming home
Monte Allums Mods
« Reply #8 on: December 06, 2007, 12:55:58 AM »
Quote from: gingataff
Quote from: gwEm
GE-7 (perfect)
 :twisted:
blah, there is no copyright in changing a resistor or cap - that is not copyrighted works.  Posting a scan of the instructions he includes in his mods, THAT would be copyright infringement.
 :twisted:
Monte Allums Mods
« Reply #9 on: December 06, 2007, 09:28:57 AM »
i have no plans to do such a thing, however - as this could get boring and technical, i have messaged HTH
