Apologies for resurrecting an old thread, but I'm just pondering how to wire up my LP Jr and all the relevant info is already here. I just wanted to clear something up:
Quote from: TwinfanThe way you have the tone pots themselves wired up in those two pics is different. This alone makes absolutely no difference to anything. It's all in the way the volume pot is connected to the tone pot.
So with regard to the tone pot itself, it makes
no difference at all if
(a) the cap connects to the middle lug and the outer lug is grounded ("modern"); or
(b) the cap connects to the outer lug and the middle lug is grounded ("vintage")?
I'm probably thinking about things too much, as usual, but I'm just a bit baffled why they bothered to show the tone pot wiring differently in the diagrams (and the ones on
this thread too). Maybe Gibson just changed the way they do things for no particular reason (not for the first time), but it does seem odd. :?
Anyway, that being the case I can use either schematic and switch between "vintage" and "modern" simply by changing
one connection - the lug on the volume control the cap connects to. Correct? Or not? :?:
