Author Topic: Custom bulit effects!  (Read 3741 times)
AdamB
« on: December 09, 2007, 03:49:11 PM »
So, a friend of mine has started building his own effects pedals, and i'm spreading the word a bit for him!
Feel free to move this if it's in the wrong section...
Ok, this is a long post, so please bear with me and take the time to read it all if you're into effects.
I've recently built myself a couple of effects pedals with extremely pleasing results, and I'd like to start building more. I'm going to build myself a couple more, but I'm also thinking of taking custom orders.
I'm not looking to make any actual profit from this at first, because I just want to build up my own experience and have a little fun in the process.
All pedals will use PCBs made by either Build Your Own Clone or General Guitar Gadgets, but I'm going to source all the parts myself rather than buy full kits This will make the end product not only more flexible in terms of options on enclosures and modifications, but also slightly cheaper.
Standard options for all pedals will be a choice of enclosure size, layout and colour, a choice on the style of knobs you would like and also a choice on the colour of the status LED. Off the top of my head, LEDs come in red, white, blue, yellow, green, orange and purple.
The pedals may not work out any cheaper than say a Boss or Digitech equivalent, but they'll have a smaller footprint, will be true bypass and will also be made up of the same high end components that are used in Keeley, Fulltone, Catalinbread, ZVex etc pedals. If you know who these manufacturers are, then you'll know what I'm talking about.
The cost for a standard pedal with no mods will depend entirely on the particular model, but an average will be somewhere between £40 and £60. As I say, I am not looking to make profit at all at this stage. I won't even be charging for labour on the first few, as I'm aiming to build up a name for myself for the future.
Possible pedals will include:
True Bypass Loops
Ok, with many pedals, your signal is running through it's circuit whether it's turned on or off. Boss, Digitech, Line 6, MXR etc etc. some pedals suck all the life out of your signal when they're not in use. Pedals with a bad bypass can ruin what should be an awesome straight up guitar to amp tone.
A true bypass loop fixes this problem by placing an pedal inside it's loop, and you then turn it on and off from the bypass box itself rather then the pedal creating the effect.
The switch used in these boxes mechanically bypasses or engages the loop, meaning that without batteries at all, you can take the offending effects pedal quite literally completely out of your signal path wen you aren't using it.
Other uses for these boxes are to group various pedals inside loops so you can turn on or off say 3 or 4 pedals with just one click.
I can build these with any number of loops, and also have the option of a 'tuner mute' switch too.
Big Muff
Can be built to standard USA re-issue, Russian Sovtek, Original 'Ram's head', original 'Triangle Knob' or 'Creamy Dreamer' specs - or can have toggle switches to flip between 2 or 3 of these models.
The stock Big Muff sound has scooped mids, so I can include a toggle switch to switch between 3 different voicings - standard scoop/flat mids/boosted mids - or I can install a sweepable midrange pot instead.
Rat
As standard, this comes with a switch to toggle between 3 modes - standard Rat, 'Big Boost' and overdrive. The standard Rat mode can be built to to Vintage Rat, Rat 2 or Turbo Rat specs, and I can also add a second toggle switch to toggle between 2 or 3 of these models if you like, meaning a potential 5 different modes on this pedal alone.
Marshall Shredmaster
Made famous by Johnny Greenwood and long since discontinued, this is a high gain distortion with 3 band EQ that regularly fetches £150+ on ebay nowadays. This one can be fine tuned for a tighter bass response by switching a couple of components inside, but I don't know of any additional mode modifications as yet.
Tubescreamer
Everyone knows what a Tubescreamer does. I can mod this for more gain, more bass, more volume, less mids...there are heaps of mods available on this one. Ask for more details if you're interested in a Tubescreamer type pedal but want options not available on standard Ibanez models.
ALL OVERDRIVE, DISTORTION AND FUZZ PEDALS CAN BE BUILT WITH A FOOTSWITCHABLE BOOST IF YOU LIKE.
MXR Phase 45, 90, 100
I can build any of the three of these models, or I can install a toggle switch to select between 2 of the 3 models.
Phase 90 can be built to 'script' or 'block' specs, and I can totally pimp this one out to include depth pot, regeneration pot, or a toggle or foot switch to take you to a univibe mode too.
Tremelo
This is a simple 2 knob trem, with depth and rate controls and the LED flashes in time with the rate it's set at.
Options include 2 sets of controls with a toggle or footswitch to flip between 2 completely different settings. Ideal to switch between a slow pulsing leslie type sound and a machine gun stuttering sound, for instance.
I could also install an expression pedal input jack, so you can control the rate of the tremelo with an external expression pedal.
Delay
A very basic but good digital delay which is voiced to sound like an analogue delay such as a Boss DM2 or DM3. As standard, this goes up to about 300 milliseconds. You increase the length of repeats up to roughly 500 milliseconds, but this will decrease the fidelity of the repeated sound somewhat. This can be desirable if you like lo fi sounds.
This WILL self oscillate.
An expression pedal input can be added to control either delay time or feedback - whichever you prefer, or you can have both if you like.
___________________________________________________________________
These are the models I can see being the most popular, but I can source PCBs to build many common effects, and modifications in the vein of what I have described for each pedal above can be carried out on anything.
Other effects I could build are:
Various overdives, distortions and fuzzes
Various boost circuits
5 knob flanger
2 knob compressor
5 knob compressor
Analogue chorus
Envelope filter
etc etc etc
If there is something you'd like me to build that I haven't mentioned, please let me know and I'll research it to see if it's possible. Particular pedals of interest may be vintage pedals that are discontinued. With many vintage pedals, I can find a wiring diagram and accurately reproduce it for you.
Just a couple more things...
An expression pedal input can replace ANY knob on ANY pedal. For instance, if you wanted to be able to control the gain control on a distortion pedal, this can be arranged. You could use it to control the speed on a phaser, the depth on a chorus etc etc. You get the idea, I'm sure.
Another service I am proposing is to modify pedals you already own. Electro Harmonix Small Clone choruses can very simply be modified to include a switch to flip between standard chorus mode and a brand new pitch vibrato mode, for example.
Do you have a pedal that you're not entirely happy with? Let me know and I'll tell you if I know of any mods to make it better.
A couple more things...
If there are a few of you wanting things built, this will make it cheaper because I can order all the parts in one go and pay only one shipping amount from each supplier I use.
I can build multiple circuits in one box. For instance:
A modulation box with 2, 3 or 4 of the following: phase, chorus, tremelo, vibrato, univibe and flange.
A dirt box with 2, 3 or 4 seperate pedals built in. I could do a really cool 4 way box with boost, overdrive, distortion and fuzz to suit all your gain needs.
A 'plug and play' multi effetcs box. For instance a cool blues type box with a Tube Scremer, Fuzz Face, Univibe and Delay. Or a box of massive stoner/doom with a Big Muff, a ZVex Fuzz Factory and a phaser.
The only limits I have, really, are whether or not I can find a wiring diagram for what you want.
Give him an email if you're interested - davidson dot pi at gmail dot com
Or, PM me for his phone number :)
SG-X/Over wound Rebel Yell
Blue SG 61 Reissue/Cold Sweat
Egnater Mod 50
Matamp 4x12
maverickf1jockey
« Reply #1 on: December 09, 2007, 05:24:40 PM »
sounds good.
Tell me the pricing you're thinking of for various options and I might well consider going for it. I could do with a better booster box (something which doesn't have a delay in it stopping me using it as a proper boost and with a footswitchable bass boost would be nice.)
If you can do expression pedals for any knob (quiet at the back) on the pedals that'd be great; I'd love to have the ability to mess with delay settings and phaser effects with my feet. For example a phaser with 2/3 expression pedals to control the effect for odd sounds (with a chorus could work like a lesley). I don't condone FX-whoring btw. For special moments I would think
AdamB
« Reply #2 on: December 09, 2007, 10:43:16 PM »
i've just posted that on his behalf mate
email him i think will be best - davidson dot pi at gmail dot com
Egnater Mod 50
Matamp 4x12
AdamB
« Reply #3 on: December 10, 2007, 11:08:08 AM »
He's had a few emails from BK guys, thanks so much :D
Egnater Mod 50
Matamp 4x12
« Reply #4 on: December 10, 2007, 10:02:09 PM »
I'd be careful about advertising that he'll make Zvex knockoffs, Zachary is VERY protective of his designs.  Expect a 'cease and decist' at the bare minimum if you go down that road.
 :twisted:
AdamB
« Reply #5 on: December 10, 2007, 10:23:04 PM »
Cheers for that mate :)
Egnater Mod 50
Matamp 4x12
badgermark
  • Mm-hai!
« Reply #6 on: December 10, 2007, 10:23:56 PM »
Just sent an email off with a pedal idea. Interesting to see how this goes, got any samples prepared of what's on offer?
JJretroTONEGOD
  • JJ Retro w/Mule + BKP90
« Reply #7 on: December 10, 2007, 11:26:58 PM »
I wonder if he could make me a ring modulator pedal/manipulator?, as there is a massive lack of them in the guitar fx industry!, and this is a shame as it's probably my favourite, so I am always messing about with software versions. The only decent ring mod pedals cost an absolute fortune! why is this?
Kilby
« Reply #8 on: December 10, 2007, 11:40:19 PM »
Err Zach has been very helpful to me in the past with a pedal issue (as in one of my own design)
He is also very helpful to others who design (or heavily mod existing pedals).
So if he offers ripped off designs, if I don't mail Zach there many others who will (some of them who are visitors to this board), simply because they owe Zach for help he has given.
If your mate  wants to offer vintage spec clones (basically something that is no longer made to original spec) thats fine.
I'm then even a bit uneasy about the legality (and morality) of selling clones of current production pedals such as the Rat (even using the original opamps)
I build my own Muff versions, but theyre tweaked to buggery even then they only get sold to friends for cost.
Goodbye London !
Davidson Effects
« Reply #9 on: December 11, 2007, 12:55:29 AM »
Hey guys,
This is my first post here. I registered because Adam very kindly posted my contact details on here etc, and I've had quite a good response from you guys already.
With regards to the ZVex thing - I wouldn't clone any of his pedals for profit at all.  The guy I offered to do that for is a friend I used to live with, and a ZVex clone certainly isn't something I'd offer to the general public.
Anyway, I'd like to make it clear that so far I haven't cloned any current production pedals at all, nevermind boutique stuff.
What I'm offering are predominantly out of production models, or are heavily tweaked.  Currently, I am basing my pedals around BYOC and GGG PCBs, but I am looking to obtain the equipment to etch my own PCBs in the near future, which means I won't be as limited in my range.
Anway, please give me a shout if you'd like a quote on anything.
Phil
Kilby
« Reply #10 on: December 11, 2007, 09:23:52 AM »
Heh, no problem, I'm just very protective of people who have treated me well.
Good luck with the venture
Goodbye London !
maverickf1jockey
« Reply #11 on: December 12, 2007, 07:39:25 AM »
Did you get my email? I mentioned an overdrive/booster with two Xpression pedals. Not that I'm trying to crowd you or anything but it is unnerving when you send an email and don't get a reply straight away (one begins to fear that it didn't go through properly). Anyway, cheers and good luck with it.
badgermark
  • Mm-hai!
« Reply #12 on: December 12, 2007, 09:31:08 AM »
I've been in touch and got some excellent and quick replies. Triangle Muff and Delay in the one box? Sexy
Davidson Effects
« Reply #13 on: December 12, 2007, 09:32:36 AM »
Hi mate,
I got an email that came through from 'Baldersons' that sounds like yours.  I did reply to it, but let me forward the response through again.
I got a little worried that I'd overlooked your email, because I've been pretty swamped with requests....but I did just check and I definitely got a response over to you.
One sec, I'll forward the email and also copy and paste into a PM here.
Phil
maverickf1jockey
« Reply #14 on: December 14, 2007, 07:23:49 AM »
Cheers I got your response so all is well.
