Author Topic: A total 'n00b' question.........  (Read 3094 times)
Brow
« on: December 10, 2007, 07:57:11 PM »
Can you run a pre-amp such as a JMP1 or a Rocktron Pirhana into the front end of a valve amp (if the EQ is set as flat as possible)?
I know you can run 1 into the return of an FX loop, but would my original question be an option if the amp didn't have an FX loop?
hamfist
Re: A total 'n00b' question.........
« Reply #1 on: December 10, 2007, 07:59:42 PM »
Quote from: Brow
Can you run a pre-amp such as a JMP1 or a Rocktron Pirhana into the front end of a valve amp (if the EQ is set as flat as possible?
The answer is "yes".  It may not be the most ideal way, tonally, to use the pre-amp, but it should work fine through any amp's clean channel.
Alan
« Reply #2 on: December 10, 2007, 10:51:52 PM »
It usually ends up way too trebly in my experience
Oli
« Reply #3 on: December 11, 2007, 12:01:50 AM »
As the other guys have said- you can run it in front of the amp, but it won't sound great. You will certainly have to tweak your patches to make them sound better.
Brow
« Reply #4 on: December 11, 2007, 12:10:42 AM »
Cheers for the replies guys :)
I'm just asking so that when I finally make up my mind what pre-amp I want, I know that I have a way of using it in the short term until I get a power amp etc :)
ibznorange
« Reply #5 on: December 15, 2007, 11:33:39 PM »
if the amp you want to run it into has an fx loop, run it into the fx loop return, to bypass the pre of the second amp.
Brow
« Reply #6 on: December 16, 2007, 01:33:25 PM »
Quote from: ibznorange
The only amp I have that has an FX loop is my 100w Marshall jcm800 and it's just too loud to be of any use. So the plan was to use the pre-amp into my Orange or Carlsbro valve heads until I can get a power amp sorted :)
