Author Topic: Removing / replacing saddles in a Gibson bridge...  (Read 8116 times)
Fourth Feline
« on: December 12, 2007, 03:45:59 PM »
Hello folks ,
I have just ordered the relevant replacement saddles to renovate a spare  'Nashville' style Gibson soap bar bridge for my '76 S.G. Standard.
Can anybody please tell me how to remove the old adjustable saddles -
 as held in place by the long intonation screws ?
 I gather that perhaps one end of the screw must be using the saddle as a nut, but  so far I have been unable to 'find the join' - however far I screw the saddles back and forth. I have tried turning the screws every which way ( but loose ) - both together and individualy, but as yet, alas - no joy.
Your insight would be most gratefully recieved... :oops:
Thank you in anticipation .
Derek
Jazz Rock
    • http://www.soundclick.com/bands/pageartist.cfm?bandID=693640
« Reply #1 on: December 12, 2007, 07:07:03 PM »
I haven't changed the saddle on a Nashville, just on the regular ABR-1 of my Epi.
But the Studio as a Nashville tune-o-matic and I believe (as for the ABR-1) you need to remove the wirestobe able to get the screws out and replace the saddle.
What kind of saddle have you gone for? I put tusq saddles and nut on my Epi and it gives a looser feel to the strings I quite enjoy.
One day I'll do the same with the Gibby.
'17 PRS SE Custom 24 - stock
'95 Epi LP classic - MQs
« Reply #2 on: December 12, 2007, 07:17:58 PM »
I'm guessing it's one of the big old rectangular 1970s Nashvilles, not the modern Nashville which is more like a wider ABR-1?
I haven't a clue how to get at the saddles on those, I'm afraid.
Fourth Feline
« Reply #3 on: December 12, 2007, 09:55:16 PM »
Hello again !
Tony at 'Axes 'R' Us' kindly e:mailed me the solution. On the old style Nashville 'Soapbar' bridges found on 70s S.G.s and Explorers, ( imagine a bridge that is a slab of steel about 1" front to back ) - you :
Screw the saddle forward from the back. When the saddle hits the front of the bridge, it 'bites' and then the rear screw head in which your screwdriver sits starts to unscrew itself, allowing easy removal of the saddle. I attach a picture of the bridge in question.
He reminds me that on a newer ABR type, there is indeed a clip that needs to be released before the saddle can be unscrewed.
I went for straight chrome plated ( brass / steel  ? ) saddles on this occasion, as I did not know the merits of TUSQ e.t.c.  Thanks for the info though Jazzrock. Had I know of tusq AND the repairability of the old saddle, I would probably have spent the new bridge money  on repairing the old one with tusq saddles, especially as the S.G. it's going on is already a very smooth and slinky guitar .
I had already purchased a new Nashville bridge from WD spares, but this new  ( Japanese)  part has soft screw heads and threads. In contrast, the original bridge is made in West Germany and is hard as nails. Seeing as the old style 'soapbar' bridge seems to be in shorter supply these days, I wanted to bring the old German one back up to standard. As good as it was, it had seen over 31 years of string wear and over eager adjustments.
Thank you for your interest !
Regards,
F.F.
