Pedalboard dilema
Started by prozacbear, December 26, 2007, 08:22:01 AM
prozacbear
Hello
This is my first post although I have read stuff on this forum quite often as I am married to Ailean, so yes I am female its not a civil partnership :)
My question is this I am working on putting together a pedalboard very slowly (since Wez is making me a guitar and I have to pay for that first). All I have at the moment is a fuzz factory (which is the best thing ever), a Big Muff (which is a bit redundant since I got the fuzz factory), and a Cry Baby (which I borrowed and havent given back yet). I used to have a Boss ME-50 but sold it because I thought it sounded a bit naff.
I've only been playing for about 6 months but during that time I've put in a lot of hours, currently I mainly play along with Muse, Metallica, Pink Floyd, Red Hot Chilli Peppers, David Bowie (before 1980), Black Sabbath, etc.
So if you were me what sort of pedal would you get next and what brand. I'm a bit picky and would rather pay extra for the best pedal first than be trying to replace it 2 months later.
DIE BENT-FACE!
IT's NB MQ PD's Blackguards C Pigs Trilogy suite Black Dogs Cold Sweats Painkillers
hamfist
Hi Sue !!!   Congrats on joining the board !
  You are not asking an easy question at all. So much actually depends on your personal tastes. I'm going to guess that you want to get you base tone right before moving on to modulation/delay/reverb effects, so I'm going to stick to dirt pedals.
 There are two ways of using drive/OD/dist/fuzz pedals with an amp. Firstly, you can use a clean amp sound as a tonal base, and then use pedals for all your drive/gain sounds. The clean channel on your Valve King would be the best for that.
 Secondly, you can use an already overdriving amp, and then push it further with pedals - Your Tiny Teror would be the clear choice for that approach, I think.
 I have used pedalboards both ways. Some pedals work best into a clean amp, some work best into a driven amp. As a general rule of thumb, I would say that Tube screamer-type pedals work best into an already cooking amp. Fuzz and higher gain pedals usually work best into a totally clean amp. In my experience I have found that there are more pedals that prefer a clean amp than those which like a driven amp.
 OK, after all that, I am going to suggest you try/get an MI Audio Crunch Box (M&M music, Soton). Reasonably cheap, true-bypass, awesome, high gain pedal - Marshall-style. I hardly ever hear of anyone being disappointed with one. I love mine. BTW, this pedal is best into a clean amp, but still OK into a driven amp.
 From the bands you have mentioned it looks like you would also appreciate a moe vintage sounding Marshall-type pedal, one that gets Plexi-JCM800 type tones (70's-80's). I'd recommend either a Himmelstrutz Fetto (very expensive - but superb !), or a Menatone King of the Britains (I have one of these in the post - you can try it out when I get it, if you like), or a Wampler Indyguitarist Plextortion. None of these is "better" than the other, all just have their own character. BTW, the Plextortion is the cheapest !
It would help me, and others, focus our suggestions if you can tell us exactly what type of tones you feel you are lacking, and whether you are going to play through a driven amp, or a clean one.
Alan
prozacbear
Watch ya Alan
I have found that through the Tiny Terror my Fuzz Factory sounds amazing, I've been really blown away by it. But through my Peavey valve king I mostly get doggy fart noises, and after an hour of fiddling I get an okish sound. So a distortion pedal that complements a Paevey Valve King would be good, maybe something with a more vintage tone than my fuzz factory.
Also when playing to solo from Californication receintly I found that I was lacking sustain, my guitar teacher suggested that I play it through a compressor. Does anyone have suggestions regarding compressor padals?
Thanks for the suggestions so far I will look into what you suggest.
DIE BENT-FACE!
prozacbear
Oh and I'll certainly be up for having a go on your Menatone King of the Britains when you get it.
Thanks
Sue
DIE BENT-FACE!
For sustain, I would value technique over a pedal. sounds boring, but I noticed a change over time, about 18months of guitarring, and sustain won't be a particular bother... unless you want about 2 hours of it
prozacbear
Mmmm, fair point, also I'm lacking a good sustaining guitar at the moment, as I had to sell my tele's for funds.
DIE BENT-FACE!
hamfist
Quote from: WillFor sustain, I would value technique over a pedal. sounds boring, but I noticed a change over time, about 18months of guitarring, and sustain won't be a particular bother... unless you want about 2 hours of it
I find that a strange comment.  Long violin-type note sustain only comes with certain levels of distortion. Compression (which saturated distortion includes anyway) also increases sustain. Also interaction between the strings and speakers at higher volume can also give sustain through feedback.
No amount of technique will give long violin-like sustain solo lines. You have to have lots of distortion, period.
Sue, the Crunch Box pedal I mentioned earlier will give you more gain and sustain than you will ever need, if you want it to.
Alan
hamfist
BTW, if you simply love the tone you are getting, yet do not have enough sustain, and cannot get any more using what you have, then a compressor will help.
 However, personallyI would never suggest a compressor for anything more than low gain tones. They tend to rob high end frequencies, and reduce playing dynamics (that is their purpose after all - to squash dynamics).  Compressors are great for cleans and tones with just a touch of dirt, but I would recommend just using the natural compression of a distorted/overdriven guitar for anything of medium gain or above.
 If you have to have a compressor, get a Barber Tone Press - best on the market - has a "blend" knob which enables you to blend the compressed signal to the dry (uncompressed) signal, to get the mix you want. From fully dry to fully compressed. It's a top quality pedal and nothing else around at the price will have the same functions.
Alan
Alan's suggestions are excellent (Welcome to the form btw). I am a clean tone player but even I have to get a bit of filth there for some of the stuff I have to do in a covers band and I used a Korg multi box(I wont go into the reasoning) which was "ok" in places but the distortions were not convincing. By chance I managed to get a Jekyll & Hyde pedal off Ebay for £63.00 the other day and I must say I am impressed with it. I use it with just a bit of grind on the Jekyll channel and a tad more on the Hyde and using my clean sounding Laney VC30, I was very pleased with the tone but, as Alan says, a compressor is a good idea for the sustain.Funnily enough yesterday I was with my brother and had the Llaney, J & H and his new USA Tele and my MIM BKP'd version and we compared notes. I used his BBE compressor for the purpose of sussing out the sweet spot and the combination sounded great- soa good overdrive and a good compressor and then a great delay pedal would be my suggestions.
Fourth Feline
Quote from: prozacbearWatch ya Alan
Hello and welcome Sue  :D
I always like a compressor in the armoury anyway.  Having said that,  I tend to be a 'clean' player. The one I swear by is the Barber 'Tone Press' - as you can blend the original signal with the compression in any mix you prefer. Because this can include no compression at all, it also doubles as a  very nice clean boost - or line driver over longer lengths of cable. My favourite setting with Telecaster or Strat is what it's instruction sheet calls " magic dust for single coils ".  Considering that we can usually get overdrive and reverb from the amp itself, I can honestly say that this is the only 'effects' pedal that I would miss. The rest I could sell tommorow. Your tastes or needs may vary of  course.
Certainly a subtle blend of compression sounds lovely if you are playing some Pink Floyd like the intro to 'Wish You Where Here' - or other mellow Dave Gilmour gems. Pedal on for the clean(ish ) soaring intro - then off again for the jangling chord voicings e.t.c
Even with a cheaper, non blendable 'full on' compressor like the Boss CS3 - I would heartily recommend you get down to a local store and have a play. The ideas of where it would / would not fit in with your tonal pallette will become clear quite quickly.
Having said that, they say a good compressor, or compressor setting only becomes apparent / can be appreciated when you switch it off again - and notice what you've lost.
Enjoy the fun !
prozacbear
Well thats certainly a lot of food for thought so far. I like the idea of the Barber 'Tone Press', as Wish You Were Here is a fav song to play, and getting sustain on a clean sound is one of the things that I'm lacking.
DIE BENT-FACE!
badgermark
Howdie.
I'm a clean/distortion sorta guy, my only pedals for a while have been a tuner and a box for dirt. How about something exotic like a wah? I'll be experimenting with delay soon, t'will be like relearning how to play i think, trying to work delay into my sound excites me.
prozacbear
I'm sure I will go exotic in the future, if only because I'm a sucker for a new toy  :D
DIE BENT-FACE!
Not much of a mention of chorus pedals - are they out of vogue at the moment?
Personally, I love a good chorus - think John Sykes on Whitesnake 1987!  DigiTech was my last chorus, Boss before that.  Stick it through a good loud clean amp with good pickups and very little else and you can't go far wrong!
Mark.
badgermark
A Small Clone from H-E will give you a nice wobble, a-la Nirvana. A fun effect, not something I've used much though. Maybe when I'm famous. Yes, when.
