Author Topic: fixing the holes in my burny  (Read 5517 times)
« on: December 29, 2007, 11:40:30 AM »
i was thinking:
pack the holes with c--ktail/match sticks (obviously not the scratchplate hole)
skim of wood filler - slightly below the top edge of the hole
very light touch of black gloss paint
however, i would appricate some advice about the best way - i like the guitar and only get one chance to get it right ;)
cheers!
« Reply #1 on: December 29, 2007, 11:55:27 AM »
I just put a black screw in my pickguard holes and I think it looks fine.
« Reply #2 on: December 29, 2007, 12:33:40 PM »
If you want it to look right I'd get a pro to do it, safe yourself a headache.
Personaly, I'd live with it - all my gear has a abundance of 'character' (or beat to shite as everyone else says)  :lol:
 :twisted:
« Reply #3 on: December 29, 2007, 02:04:16 PM »
You could shove a dowel in it, if you can find ones small enough, but you'd have to sand it off a bit, shove the dowel in, cut it off, sand it smooth, spray spray spray (with obvious masking so nothing else gets covered in.. spray)
That's how I would try it, but you could just take it to a pro. Best way and safe, money shouldn't matter I should hope not. :P
« Reply #4 on: December 29, 2007, 02:28:03 PM »
I wouldnt bother with dowels or matchsticks/toothpicks but i might make a thick filler with epoxy and wood dust to do most of the fill (but importantly, not overfill the hole) on the bigger holes - then i would drop fill with lacquer - lots of stuff about drop filling on the web
« Reply #5 on: December 29, 2007, 02:54:50 PM »
It's a bit low-tech, but you can (or used to be able to) get car touch-up paint in little tubes with a brush, like nail polish.  It's quite thick, so it builds up quickly to the thickness of the original finish, and dries fast.  Once the spot-repairs are fully dry, sand them level with successively finer grades of wet-or-dry paper, then polish with T-Cut.
I used that method on a couple of highly-chipped black guitars - my Hamer Vector and an old PRS EG - and it worked a treat.
« Reply #6 on: December 29, 2007, 03:15:20 PM »
Quote from: Philly Q
probably the best thing for attempting this kind of stuff at home.  - but you still need to fill the hole with something a little more solid to stop the lacquer just shrinking into the hole within a few months.. thats why i would do the epoxy fill first and just use thickened lacquer for the final fill - - luckily the stuff in the touch up pens is already pretty thick and a bit more practical than getting a gallon of nitro  for a few screw holes.
I have a jar of older lacquer i leave on my windowsill that has thickened a bit too much with age but is great for doing fills
« Reply #7 on: December 29, 2007, 03:33:22 PM »
Quote from: WezV
Yeah exactly, I meant after filling the hole itself, of course!  :)
« Reply #8 on: December 30, 2007, 04:49:09 PM »
thanks for the advice - i'm going to go for it ;)
i'm sure it won't be 100% as new - but that doesn't matter, as i'm hoping the result will be at least better than the holes. i'll get some car touchup paint.
