Author Topic: Are BKPs standard size?  (Read 2596 times)
hhcave
« on: January 02, 2008, 05:27:05 AM »
Hey,
I have a carvin guitar which i know can fit Seymour Duncans and DiMarzios but am not sure about BKPs - are BKPs the same size as these pickups?
Also, can anyone suggest an HSS set for me? I play mostly instrumental rock/jazz fusion and my guitar is a superstrat, mahogany, neck thru body with a maple (2 strips of mahogany) neck and ebony fretboard....oh and it has a floyd rose....
And can anyone explain to me why exactly the miracle man is so much better than EMGs (in a Les Paul)? Oh AND, are 2x Miracle Men a good combo for Melodic Death Metal stuff? ie. In Flames, Dark Tranquility, Lamb Of God etc... or would Warpigs be better?
Thanks
Gisbon Les Paul Custom with MMs
Bodenhamer modded Maxon OD808
Mesa/Boogie F-50
Marshall TSL 2x12
« Reply #1 on: January 02, 2008, 07:27:05 AM »
I can't answer your questions about what pickups would achieve what you are after but I can advise that BKPs are standard sized.
« Reply #2 on: January 02, 2008, 12:04:57 PM »
...however humbuckers from other manufacturers may occasionally not be standard size. (important to note sometimes when changing standard pickups)
Re: Are BKPs standard size?
« Reply #3 on: January 02, 2008, 12:05:17 PM »
Quote from: hhcave
I would have been able to answer that for you today, but at the guys at the guitar shop STILL haven't fixed my guitar. So I can't post clips, but I play it and I have a Cold Sweat in the neck and a Ceramic Warpig in the bridge.
My next set however, would be a calibrated Miracle Man set. Which are good (I think hopefully) for harmonics.
BKPs are standard size.
Through much effort in searching for you, I think it's safe enough to go with a Nailbomb/Triology/Triology wound up to 21k, like in your last thread.
http://bareknucklepickups.co.uk/forum/viewtopic.php?t=10451&highlight=superstrat+pickups
hhcave
« Reply #4 on: January 02, 2008, 03:06:14 PM »
thanks for the suggestions
Mesa/Boogie F-50
Marshall TSL 2x12
« Reply #5 on: January 02, 2008, 03:18:52 PM »
I think the actual question is, Are Carvin pickups standard size? BK pups will fit in 99% of all guitars fitted with Fender, Gibson and aftermarket P90, single coil, and humbucking pickups. Carvin does not use aftermarket pups, but designs/builds their own.
I'm almost entirely sure the answer to the question posed above is no, but am not sure what modifications need to be done to make a BK fit.
« Reply #6 on: January 02, 2008, 04:44:32 PM »
Quote from: TwilightOdyssey
Good point - if the Carvin is the HSS guitar you mentioned, then Carvin single-coils are certainly different from standard - they don't have the "triangular" base plate.
I think Carvin humbuckers are standard size, but they use a 3-screw mounting ring you'd need to modify or replace.
