Strapbutton screw came out
Started by AngusYoung01, January 04, 2008, 03:05:43 PM
AngusYoung01
shitee, it came out of my Charvel, like just slidout as if there was no tread for it. It also keeps the neckbolted on. I have screwed it back in, and it seems ok, but if it comes out again, should I use some kind of glue? I have no interest of ever removing the neck, if that helps.
Some toothpicks and wood glue will sort that out.  It'll happen again if you don't fix it now.....
so  is it like a neck screw that goes through a strap button?
thats a bit more worrying because maple necks (i presume thats what it is) shouldnt strip out as easily.
Either way the toothpick will see you right - just dont pour loads of glue in the hole because it might make removing the neck a problem later.  A little smear on the toothpick should do
AngusYoung01
What exactly am I doing with the toothpick  :lol:
Transcend
Quote from: AngusYoung01What exactly am I doing with the toothpick  :lol:
put it in the hole where the screw was
matches also work (without heads)
then put the glue on it and screw your sscrew back in
AngusYoung01
Ah ok. The whole toothpick/ headless match?
Transcend
Quote from: AngusYoung01Ah ok. The whole toothpick/ headless match?
just enough to make it so you can screw it together firmly.
its basically just to fill the hole in,
It's a quick-easy replacement to put wood where there wasn't, then screw the screw back in.
Which sounds like a sexually inneuendo.
AngusYoung01
Cheers guys, these insider tricks are really helping  :D
machine_of_god
I like to put wood where there isn't any...!
Giggidy giggidy!
BKP guitars:
Epiphone Dot Studio (NB bridge, MQ neck)
Gibson LP Studio (MM bridge, CS neck)
AngusYoung01
Quote from: machine_of_godI like to put wood where there isn't any...!
Giggidy giggidy!
Aaallriiiight 8)
