Ubersinner?
Started by brewboy73, January 05, 2008, 10:18:15 PM
brewboy73
Cant find any info about the Ubersinner. Can anyone get me some info on this pup? Thanks
Is it not a Sinner with extra winds... voiced the same as the Sinner, just about 20k resistance or something
ilÿti
I believe "uber" is just a nick-name for an overwound and thus brewtally methull Sinner. :D
Crawlers, Mule-7s
machine_of_god
It must cause a nationwide shortage of enamel wire every time Tim makes one of those...
8)
BKP guitars:
Epiphone Dot Studio (NB bridge, MQ neck)
Gibson LP Studio (MM bridge, CS neck)
f*ck sake, a 22k single coil - thats Warpig territory  :o
It 'almost' makes me want to buy a Strat to try one out.
Sailor Charon
Quote from: HEAVIER THAN HELLf*ck sake, a 22k single coil - thats Warpig territory  :o
Flip me. I thought that my Trinity Suite bridge was loud.
If anything it sounds quite a bit hotter than a pig. The fact its a single coil means it screams. And I dont know what it sounds like without it, but I got a zinc-steel base plate and the low end is thunderous. Pretty tight too.
Ravens Creed
Hi guys, first post.
I ordered a calibrated Ceramic Warpig/Sinner set for my '91 ESP Horizon custom and whilst the C-Pig is absolute perfection, the Sinner is simply ridiculous. Both rated at 23k but the Sinner is wound down as low as I can get it but still screams and is on the edge of feeding back unless I back the vol off a bit.
I have never had to do that before in my life and this is a single Coil!!!!!
Outrageous.
It does sound like a single coil and yet .....doesnt. More like a P90 possesed with Satans own soul.
Ubersinner is one way of describing it. I'd call it a Blasphemer!  :wink:
Welcome, raven.
And if you put a sinner in a neck position then you are even more of a mental-ouput-pickup-freak than I (and my warpigs, sinner and 23k miracle man).  8)
Ravens Creed
Thanks man.
Tim suggested it. I thought I was getting a "normal"  :lol:  Sinner and then this 23k freak showed up.
I'm still not 100% sure its not too much and bear in mind I'll be using this guitar for Death and Thrash metal.
Sod it. In for a penny, in for a pound of sound.
sambo
Could you be utterly ridiculous and rig two uber-sinners together in the form of a humbucker? Would that destroy the world?
Ravens Creed
I was thinking the same thing, but I doubt even the ghost of Evel Knieval would try that.
Sailor Charon
Quote from: samboCould you be utterly ridiculous and rig two uber-sinners together in the form of a humbucker? Would that destroy the world?
Well, you could. If you wanted the pickup equivalent of the Bugatti Veyron. Be warned, it will turn you into Jeremy Clarkson :)
machine_of_god
Quote from: Sailor Charon
POWEEEEEEEEEEER!
BKP guitars:
