Looking to upgrade my Ibanez Universe' pickups
Started by CyanideChris@Gmail.Com, January 11, 2008, 07:02:15 PM
Hey guys, I'm looking to upgrade the pickups on my Ibanez Universe.
Just looking for advice/suggestions etc !
UV Prestige neck
5pc. maple/ wenge neck material
Basswood body
24 large frets
Bound rosewood finger board
Edge Pro 7 bridge
I will be playing stuff like Nevermore, Shatter Messiah, Outworld, To-Mera, Dream Theater, lots of death metal.
Also stuff like Vai and other instrumental type music.
I was thinking about a Ceramic Warpig for the bridge and a Cold Sweat for the neck, I'm also looking for a single coil which I have no idea about to be honest :P
So yeah, what are you guys inputs? Are there any known soundclips of a Universe with BKPs?
Cheers :D
Good choices.
A miracle man bridge would also work really well.
I wouldnt change the cold sweat though.
ilÿti
Yeah, MM+CS is likely gonna fit it very well. Going for an MM-set would be if you're going for a less paf-like and more modern (like the stock pickups, and the bands mentioned) but everyone loves CS for shred. I did hear a great 80s guitar hero rock clip with the MM set and it seems to do Petrucci/Vai tones very well.
Crawlers, Mule-7s
Thanks guys.
Well it is rather hard deciding on what pickups to get when I have very little idea of their sounds.
So I'll put it this way, would there be any disadvantages choosing a specific set of pickups over an other set?
e.g. CWP + Coldsweat
vs
Miracle Man + Coldsweat
- What advantages and disadvantages do they both have playing them next to eachother?
CWP and MM back to back, in my experience:
The CPig has a fuller, more grinding mid range, its quite a bit hotter and bigger sounding. It arguably has more low end, but I dont think theres that much in it, its probably just that its driving the amp that much harder.
MM: Sweeter high end adn quite a bit more of it, less compressed, more scooped mids and smoother sound, but with a fat low midrange.
To sum up the vibes as I see them, the C-Pig is clinically precise brutality, the MM is more refined and articulate but more than capable of brutal.
You seem to like a lot of smooth, scooped sounds, so I'd go for the MM.
Edit: it has to be noted that both are insanely tight.
Thanks for all the info :D you've been a great help.
But yeah I'm going to have to think about this..
Oh yeah and I'm looking for the most 'brutal' palm mutes ever haha : P
I play through an ENGL Savage Special Edition + Mesa Rectifier cab as an extra note.
Brutal PMs = C-Pig.
The most brutal PMs I have yet to find (after trying SO many metal pickups!!!)
The finest combination of devastating and clear and musical in the industry.
And youre welcome!
Sounds good :D
Except - I just went to order them, and on the order form there is no option to choose between alnico and ceramic magnets on the 7 string Warpigs, what do I doooooo :O?
*stuck*
I sent an email through the contact form but yeah I'll just type that out here too.
I always ring up, but I believe you can ask for it in some special requests or comments or something section.
Oh, yeah, what are you after from the single?
Ahh cool.
Well I'm not sure, probably a nice bright chimey clean sound, for use with a bit of chorus and the like.
I'm not sure if they do 7 string singles though? I was just going to leave that out but if I can get one then I definitely would..
Now you mention it I dont know if Tim does them either.
JamesHealey
If you have one of the newer UV777BK's go for it and upgrade the pickups.. I'd suggest Miracle Man bridge and neck.
If you have and older one like say a UV7PWH, keep the originals at hand as those guitars are going up and up in value.
JamesHealey
oh yea and just to mention my dream guitar ever since I was about 14 was the UV77MC
kmanick
Great thread as i just got a 7620 and it''s specs are very similar to the Universe (woods wise)
I replaced the B-2 in the bridge with an Evolution 7 and I'm not really thrilled with it.
I've got a Nailbomb in the bridge of my Carvin 7 and it stomps all over the Evo. (but that's an all Mahogany guitar) the 7620 is basswood and I'm thinking a Miracle Man might just do the trick?
For reference I'm playing a lot of the same stuff here, Nevermore, Dream theater, Arch Enemy and Instrumental shred ( but my Carvin 7 handles that already). I'm playing thru a JSX into a Legacy top (V30's).
so MM the way to go?
can I be the devil on your shoulder?
