Apache - THIN is the new FAT
Started by hunter, January 11, 2008, 11:08:39 PM
Received my Apache Set today and threw it in the Tokai Strat (an 80s Goldstar, this was my first guitar in fact).
I am speechless. It screams like nothing I ever had before. It has so much punch, clarity and dirt at the same time, it's almost too much of everything.
Obviously I had to add a pedal before the amp to get into same gain teritorry as with my HB equipped guitars, but OMG !!!! It has turned my "always not quite right" Tokai into a mean scream dream machine. Actually bought this set for the cleans but I am just coming back from 3 hours straight shredding my a... off and now I realise I didn't even try 'em clean yet   :P
Clips promised for tomorrow, look forward to hopefully hear some killer tones (if I will get it right 'on tape' without my SM57 that died last week)...
lulusg
Glad to hear you liked them, they are that good...Cheers!
Just passing by
Nice man! And waiting to hear it! You always make top stuff records!
They are superb Hunter. They get "dirty" if you want them to and really kick it out. I recorded last week and did a couple of tracks for the covers band demo and used  my amp cranked with a Jekyll & Hyde pedal in front and the sound in the studio was fantastic. I am betting, however, that the cleans will really blow you away.
Quote from: FernandoEstevesNice man! And waiting to hear it! You always make top stuff records!
Thanks, but it's a bit difficult to get it sound right without my usual mic (SM57) but I gave it a try.
Quote from: 38thBeatleThey are superb Hunter. They get "dirty" if you want them to and really kick it out. I am betting, however, that the cleans will really blow you away.
Usually I don't care about cleans very much but the Apaches are indeed very nice. What I am a bit struggling is pickup height, as I am a newbie to SCs. Any advise there?
check em out http://bareknucklepickups.co.uk/forum/viewtopic.php?t=10959
Henk
Quote from: hunterUsually I don't care about cleans very much but the Apaches are indeed very nice. What I am a bit struggling is pickup height, as I am a newbie to SCs. Any advise there?
Im not an expert on SC's(dont have apaches either for that matter), but i had problem at first setting the pickups to the right hight because the 'wood' tone is not as distinct(or better said is very different) then with the gibsons i have. After considering some options i have now set them up on pinch harmonics(checked high and low positions) height, so instead of setting them up on 'wood' i set them up on a mix of sustain, clarity(string) and resonance in a way the harmonics sounded best.
The bridge SC i just set to a point where the tone didnt bite too much anymore the middle and neck are set a bit lower, the middle is set the lowest.
After setting the height you should set the balance between low and high strings.
Listening to the clips i think you have the bridge SC set up quite well but the neck and middle a tad too high.
Quote from: Henk
That's a good idea, I think you're right!
Many thanks for the tip!
I will dig out my Haynes Stratocaster manual as it has recommended heights in it.I probably get to it tomorrow.
