line 6 spider question
Started by jibidy, January 25, 2008, 12:09:16 PM
jibidy
Is the poweramp a real tube power amp?
Would you be able to use a Hotplate?
im thinkin the 112 but hotplate into my 212"
good idea?
Transcend
depends whether you mean the spider or the spider valve.
and yes its a full valve amp.
I dont see why you wouldnt be able to use a hotplate
jibidy
Yer i meant the spider valve. i was just unsure because in the hotplate pdf. manual it said DO NOT USE A SOLID STATE POWERAMP.
The Line6 blurb lists it as a valve output stage so I don't see why not.
