Author Topic: Jackson Dk2m Dinky Used off eBay  (Read 3208 times)
ReverseHeadStock
« on: February 06, 2008, 02:33:19 AM »
I just got a DK2M dinky guitar off eBay, I always wanted to play around with a Floyd Rose bridge and it was 400 $ US, so I thought it was a pretty good deal. (It looks bad ass too :))
Anyways, I messed around with it for a while and the strings went out of tune :(, maybe it's because it's a licensed Floyd Rose, I read about it and the one this guitar has a Low Profile Licensed bridge, and I was wondering if the Original Floyd Rose would fit in the guitar?(Considering to get an original or Ping/Schaller made :))
Or would I have to cut more of the wood??
Thanks!!
Kang
ozzuk
« Reply #1 on: February 06, 2008, 02:12:40 PM »
It might be that the bridge is not level and that means it will not stay in tune if you dive, I need to write up a Floyd tuning guide I have written a guide over on shredaholic.com in the tech section check that out it may help you with the Floyd tuning instabillity...
I have had zero problems with my schaller and gotoh unit's...
The licensed vibrato's can be finicky my LTD one was a bit arkward to tune but once it was tuned  was fine my amverick F1 is a bit finicky aswell but fine when sorted...
www.shreadaholic.com go to the tech section and look for the floyd guide..
ReverseHeadStock
« Reply #2 on: February 06, 2008, 09:02:31 PM »
Alright, thanks a ton! :)
silentrage
« Reply #3 on: February 07, 2008, 02:13:51 AM »
I had the same problem with a kramer I bought off ebay.
Later I took off the back cover and found that of the 5 springs that were supposed to be there, there were 4, that made it off balance. As soon as I took 1 out, it was a lot better and only went slightly out of tune when I used it.
I suspect that has to do with the knives being too worn down, as the guitar is made in 85.
So maybe you have a similar problem?
p.s. can anyone confirm my knives theory? :)
Transcend
« Reply #4 on: February 07, 2008, 09:06:48 AM »
i always use only 3 springs on guitars with floyds.
also this may sound stupid but did you lock all the nuts?
i didnt when i got my first guitar witha  floyd it drover me mad till i realised how stupid i was.
ReverseHeadStock
« Reply #5 on: February 07, 2008, 09:25:46 AM »
Haha, yea I locked my nuts  :wink:
JDC
« Reply #6 on: February 07, 2008, 10:12:54 AM »
Quote from: silentrage
I've heard the knives wear out from adjusting action without loosening the string, which might explain why my RR3 goes slightly sharp after I pull up the bar or stays slightly flat if I dive
not that I can even use the bar now because I rusted the inside of the hole it goes in, arrrrr!!!!
Transcend
« Reply #7 on: February 07, 2008, 10:22:26 AM »
Quote from: JDC
a rounded file will fix that for you
« Reply #8 on: February 07, 2008, 05:59:06 PM »
Quote from: JDC
don't think so...
