Author Topic: BUZZZ  (Read 3723 times)
Orkestra
BUZZZ
« on: February 08, 2008, 01:49:28 PM »
Hey guys, i was messing around today and decided to put a Dimarzio humbucker to my RR1, i matched everything up, everything works fine...
but now for some reason theres an earth buzz when i take my hand of the strings or bridge, i attepted to fix it, as its a common problem... but nothing seems to have worked, i've insulated everything possible, re-earthed everything...
what the $%&#?
ailean
BUZZZ
« Reply #1 on: February 09, 2008, 12:46:53 AM »
Have you re-soldered everything? You might have a dry solder somewhere.
Gibson LP std + Nailbomb set
BUZZZ
« Reply #2 on: February 09, 2008, 01:20:54 PM »
Make sure that there is only one path to earth.  In other words don't have multiple wires to more than one pot.  If you do then you can set up an earth loop that way.
