Ok fellas, so i am determined, with the little amount of money that i make this summer, to finally purchase myself a valve amp. I don't want to break the bank on this one and these two, seemingly great, new additions to the valve amp world are like a dream come true: compact, portable, low-wattage, etc. etc.
So EGNATER'S REBEL:
- As far as i can discern it will be 500 USD
- Switchable wattage from 1W to 20W
- Select between 6v6 and el84's
- Effects loop
- Weighs 5 pounds
There is limited info about this amp online, and the egnater site doesn't even say anything about it :rock:
Next contender:
BLACKHEART'S Killer Ant:
- <1 Watt RMS, Single-Ended, Class A, 1W resistors in the signal path
- Outputs: 1 x 16 ohm jack, 1 x 8 ohm jack, 1 x 4 ohm jack
- Solid State Rectifier :?
- DC Power to filaments for super quiet operation
- 139.99 USD estimated street price
(Designed to mate with the Killer Ant (it's not really as disgusting as that sounds), Blackheart's new slightly-larger-than-palm-sized BH110 "Killer Cab" $139.99 USD street price)
THE BATTLE (COMMENCE DESTRUCTION :twisted:):
Which one do you think would be better suited for a pedal arsenal (something that i intend on building over time). The Egnater has a dedicated effects loop, but effects loops tend to suck out the tiniest bit of tone (so i'm told). The killer ant on the other hand has no such thing, but it is solid-state rectified. Would the Egnater also be solid state rectified you think? The killer ant is incredibly cheaper but the Egnater might be more versitile, i'm not quite sure... There is something to be said of the simplicity of just a volume control like on the Killer Ant, which means that it actually might be just as good, if not better, with pedals as the Rebel. So these are some of the questions that are sifting around in my head right now. I want something compact, one of these two is the answer. I am leaning towards the Killer Ant, but i really don't know anything about rectifiers so someone may have to clarify that for me. Feel free to add in any extra arguments!
If you don't really care to answer, at least you can thank me for dumping some amp porn on ya :P
