Author Topic: Buying a new amp  (Read 2416 times)
hhcave
Buying a new amp
« on: February 22, 2008, 04:19:40 PM »
Hey,
Im looking to get a new amp because i've had to get rid of my current amp and the backup solid state just doesn't cut it - my budget is around 700 quid and im looking a decent, solid tube amp (all-rounder even though i mainly play metal/instrumental rock)
The reason i don't need it to be ultra high gain is because im planning on building up a good pedal board which will include a good distortion pedal (Distortius Maximus  :twisted: )
What would you suggest? I've been looking at the Tiny Terror - what do you guys think of it? Also i have access to a 6505 at the local store but can't try it for a while - what are those like?
Thanks
Gisbon Les Paul Custom with MMs
Bodenhamer modded Maxon OD808
Mesa/Boogie F-50
Marshall TSL 2x12
Buying a new amp
« Reply #1 on: February 22, 2008, 04:54:05 PM »
Engl Screamer you can buy a new one from Thomann for that price - 4 channels, only 1 EQ, superb clean, and great dirty - Goes from hifi clean to all out metal distortion. Its got quite a modern voicing, and takes pedals brilliantly.
Buying a new amp
« Reply #2 on: February 22, 2008, 05:23:21 PM »
screamer is nice. i'd also take a look at a laney tt combo, if you can find one. i've only tried the head, but assuming the combo sounds similar, should be nice for what you want- real nice 80's type of lead tone, which sounds like what you want. koch might be worth a look too.
probably a bunch of options, though.
ailean
Buying a new amp
« Reply #3 on: February 22, 2008, 07:16:36 PM »
I'm a fan of Orange so I'll plug them.
The TT is nice amp, and you can get that plus a cab with change from 700 quid. I'd also look into the Rocker range (the rockerverb is a bit out of that price range) I've seen a Rocker 30 combo for about 600.
If you already own a cab then check out the AD30 head, that's around £700.
Gibson LP std + Nailbomb set
hhcave
Buying a new amp
« Reply #4 on: February 22, 2008, 10:42:15 PM »
hmmm okay, i'll have a look at the Engl Screamer...but if i were to buy that i would have to import it into hong kong (which is where the amp will be)... i think realistically, the only choices are some sort of Orange amp or the 6505?
Mesa/Boogie F-50
Marshall TSL 2x12
hamfist
Buying a new amp
« Reply #5 on: February 23, 2008, 08:24:37 AM »
If you are using pedal-based distortion, surely you need to look at a Fender Hot Rod Deluxe or Blues Deluxe. These are very well respected loud, clean amps, which are globally used for pedal-based rigs on a budget.
  The AC30CC is also an excellent, well-respected clean base for a pedal-base rig. Despite it's meagre 30 Watts, it has a lot of clean headroom. It's almost supernaturally loud for a 30 Watter.
   If you are intending to gig with the amp at all, steer clear of the Tiny terror. it simply will not have the grunt (or clean headroom) to stick with a loud gigging band. Rehearsal, yes. Quiet drummer yes. But why limit yourself.
Please also clarify whether you need a combo or whether a head will do.
Kilby
Buying a new amp
« Reply #6 on: February 23, 2008, 09:08:54 PM »
Quote from: hamfist
As I remember when the average AC30 is cooking it's putting out around 48 watts. Though I'm sure that HTH can provide better figures
Goodbye London !
