Author Topic: Which is the best out of the new blackstar ht series pedals?  (Read 4884 times)
ish
« on: March 07, 2008, 05:55:08 PM »
Which is the best?
Does anyone know of any sound samples on the net so i can listen to em? as i am intested in gettin one but wanna hear it and poss play one before i buy.
If you've played one wat do u think?
« Reply #1 on: March 07, 2008, 05:57:03 PM »
Well it really depends what you want to play...
I'd guess that the overdrive pedal sounds best for overdrive, boost for boost, distortion for distortion... :roll:
Welcome to the forum
ish
pedals
« Reply #2 on: March 07, 2008, 06:02:07 PM »
cheers, well im a lead guitarist in a metal band, but i play a wide range, i like playin everything i guess, i play alot of stuff like dragon force, steve vai,marty friedman, real fast solo with shed elements so i wanna real hot tone that'll will sing when im playin soloing as well as a awsome metal sound for wen im doin riffs etc i've been lookin at the dist x that sounds pretty ace
ish
« Reply #3 on: March 07, 2008, 06:11:21 PM »
any suggestions??
hhcave
« Reply #4 on: March 07, 2008, 06:15:42 PM »
Yeah the Distortion X is really good - really genuine distortion sound because of the valve in it...
But if you want a distortion pedal for all out medal i would definately go for the Krank Distortus Maximus
Gisbon Les Paul Custom with MMs
Bodenhamer modded Maxon OD808
Mesa/Boogie F-50
Marshall TSL 2x12
ish
peds
« Reply #5 on: March 07, 2008, 06:21:57 PM »
how bad is the gain shortage that they say on sites?
ish
ep
« Reply #6 on: March 07, 2008, 06:56:32 PM »
thing is i got a engl powerball and its awsome, so i wanna get the best out of it and with a great distortion pedal it would be a match made in heaven.
« Reply #7 on: March 07, 2008, 09:22:05 PM »
HT-Dual does everything the other pedals does for £139.
Complete no brainer - the Dual rules.  Fantastic pedal.
opprobrium_9
« Reply #8 on: March 07, 2008, 09:38:27 PM »
Quote from: Twinfan
I can't wait to get one of these, i have been drooling over one for ages!
« Reply #9 on: March 07, 2008, 10:02:41 PM »
They're a valve pre-amp in a box for £139.  Unbelieveable pedal.
« Reply #10 on: March 07, 2008, 11:29:29 PM »
I'm really interested in the HT Dual now, I didnt realise it has a speaker emulated output. Any idea how thatd sound going into a pair of half decent headphones, or will it not have enough power to drive them? Seems like it might be a good practise "amp" and also something to use to boost my real amp at home, or does it not do a tubescreamer style overdrive effect so well?
edit - found some clips of it direct in, sounds good on lower gain but when the gain goes up it sounds much more artificial :( The Award Session JD-10 sounds good and more "real" from the clips on their site but I they're not exactly the kinda style I'd play..
« Reply #11 on: March 07, 2008, 11:43:03 PM »
It's not a tubescreamer.  It works best when your amp is set for clean/light crunch then you have a rock rhythm and a solo setting on the Blackstar.
Basically, it turns a single channel amp into a three channel one.
« Reply #12 on: March 08, 2008, 08:32:35 AM »
Quote
+1.  I push my Orange in this way, cooler than cool!
Mark.
« Reply #13 on: March 08, 2008, 10:21:15 AM »
Reckon it'd work with a JCM800? I'm dubious because the Mesa V-Twin sounded TERRIBLE in front of the '800.
« Reply #14 on: March 08, 2008, 07:05:40 PM »
Set the 800 clean-ish, and yes.
Tom - clips on the web aren't the be-all and end-all.  You should try one out in person  :)
