Started by noodleplugerine, March 08, 2008, 03:39:03 PM
Quote from: noodleplugerinehttp://www.wdmusic.com/roller_nut_black_24598_prd1.htm this looks good - Combined with some Sperzels should be good right?or these:Will Sperzels keep in tune as well as a locking nut?
Quote from: WillNot to sure, but also is it not preferable to have down pressure, as to stop strings jumping the nut slots?irrelevant if you have string tree or the like
Quote from: FELINEGUITARSQuote from: noodleplugerinehttp://www.wdmusic.com/roller_nut_black_24598_prd1.htm this looks good - Combined with some Sperzels should be good right?or these:Will Sperzels keep in tune as well as a locking nut?These wont work unless you shave off 1.5mm f the fingerboard as the roller is set back from the line where the nut should start It would ruin your intonation
Quote from: noodleplugerineAny alternative suggestions? Or would taking the clamps off be fine?
Quote from: FELINEGUITARSYes - take the clamps offOR USE AN EBANOL REPLACEMENT ONE
