Laney GH50L pedal advice
Started by Dave_the_rave, March 09, 2008, 12:58:31 PM
Dave_the_rave
im gonna be getting a laney gh50l, and playing with a jackson rr24 (for metal ofc), and ive heard some people say that with the gh50l its worth getting some sort of boost pedal, like getting a tube screamer or something like that. any thoughts chums?
Crazy_Joe
Modded SD-1, awesome sound!
Black Dogs
hamfist
Quote from: Dave_the_raveim gonna be getting a laney gh50l, and playing with a jackson rr24 (for metal ofc), and ive heard some people say that with the gh50l its worth getting some sort of boost pedal, like getting a tube screamer or something like that. any thoughts chums?
I heartily recommend an MI Audio Blue Bloy Deluxe as an Overdrive/boost pedal. I haven't found an amp it doesn't work really well with. They aren't the cheapest, yet not overly expensive either.
  M & M Music in St.Mary's street stock them if you want to "try before you buy".
Alan
Dave_the_rave
might just have to do that as its on 2 mins walk from me :P thing is, another point to this is with the laney is it definately a necessity? ofc if it is what should i go for being the obvious question :P
Bad Monkey by Digitech is meant to be a really good boost, and its only about £30 I think. I even like my Behringer tubescreamer copy which was like £10-15 :lol:
btw this is the amp with no boost and mules going into it, just to show you the tightness with a guitar straight in http://www.soundclick.com/bands/page_songInfo.cfm?bandID=493678&songID=4951909
Nolly
Quote from: Dave_the_ravemight just have to do that as its on 2 mins walk from me :P thing is, another point to this is with the laney is it definately a necessity? ofc if it is what should i go for being the obvious question :P
It has plenty of gain on it's own, but if you want modern metal, using a TS-type pedal to tighten it up works wonders.
waves
is that where you set the drive to 0?
which is good for the metal tightening up purpose?
Spitfire
im a bit fan of the standard ibanez ts-9
Fender Telecaster
Jackson KV-4
Starfield SVA-1
Dave_the_rave
QuoteIt has plenty of gain on it's own, but if you want modern metal, using a TS-type pedal to tighten it up works wonders.
thats my point - what would be a good idea? i play mostly 80's 90's style heavy metal but occasionally do dabble in the odd bit of children of bodom etc, so would a tubescreamer be the way to go or would something else be more suitable?
waves
i've never played with one, but i heard the maxon od808 was the one for tightening up high gain. dunno if thats true?
Nolly
Quote from: wavesis that where you set the drive to 0?
Pretty much, yes, but the effect will still happen regardless of the amount of drive you have on the pedal.
OD pedals have a bass filter that cuts frequencies below a certain point, leaving you with a far tighter sound. Tubescreamers are often used as their mid hump adds extra cut and grind to the sound, which can result in much chuggier palm mutes and can help you punch through a band mix a little better.
A regular poster on the SevenString forums mods and builds pedals. He makes pedals with the metal player in mind, and from all reports his pedals sound brilliant. As soon as I pay off my Blackmachine, I'll be getting myself one of his "Bloody Murder" overdrives (don't worry, you can have it named and painted whatever you'd like!), which is essentially a TS clone, built up from scratch with lowest tolerance parts, designed specifically for metal players.
His stuff is very well priced, especially taking into account the exchange rate at the moment. (shipping to the UK is $10 btw)
His website can be found here: Bodenhamer Electronics
zf
Quote from: wavesi've never played with one, but i heard the maxon od808 was the one for tightening up high gain. dunno if thats true?
That's what Killswitch Engage uses (or at least did on End of Heartache), so there's probably some truth to that :)
[url="//www.embreach.net"]www.embreach.net[/url] /// Ibanez J-custom (AMs), PRS Singlecut Satin (PKs), Jackson Dinky (HD+Trilogies)
Elliot
All tubescreamers and associated clones do this - if true bypass is wot you want then go Maxon - but if you want fun AND cash just get the cheaper ones i.e. a Behringer Vintage Tube Overdrive (the Green one), a Ibanez TS7 or a Bad Monkey.  I have vintage TS808 that I bought 2nd hand in 1984 and the TS7 can capture that sound.  The Monkey too, although it doesn't quite have the output of the TS808 or the TS7.  For max output go for the HBE Powerscreamer - its all the above and more.
ACHIEVE PERFECTION
And i think As I Lay Dying use the Maxon as well. I have the Bad Monkey and a Boss SD-1 which i modded with a kit from Monte Allums (GT mod). If you want a heavy and tight sound go with the Bad Monkey. The SD-1 before modding sounded too middy while after the mod - though it didn't sound middy - it sounded thin compared to the BM. I tigthened the sound but the bad monkey is the clear winner in all three amps (engl powerball, lee jackson xls-1000, marshall 6100LM) that i tried it with. Plus its cheaper. i would like to try the maxon as well
Dave_the_rave
hmm sounds like the ts's or the bad monkey are probably the best sort of options for a boost to my shreddy metal solos then huh?
